Hey guys, got a quick ? for ya's.
My mom has a 1999 chevy suburban w/350 engine. Had to replace the battery. Checked the charge rate w/ new battery installed--14.7-14.9vdc. Im wondering if this is too high?? I thought the ideal charge rate was 14.4. I DONT want the battery to cook, then have to replace the new battery AND an alternator. (If Im not mistaken, the voltage regulator is inside the alternator?)
Just keep an eye on the water level. If it boils out, be concerned, otherwise it is ok. My Ford tended to put out close to 15v also, but it didnt cause problems.
I did not know you could do such a thing. I thought once any part of the alternator was failing or dead it was a remove and replace deal. I have heard of doing it on the older stuff, but nothing in my era of being a mechanic. Should any parts store carry what it takes to fix it??
