Installing limited slip
Old Feb 12, 2011 | 12:34 PM
thinksnow's Avatar
thinksnow
I've been pondering trying to install the Detroit Truetrac myself. Has anyone tried it yet? How bad was it?
Old Feb 12, 2011 | 04:50 PM
wulfman's Avatar
wulfman
Have you ever set up a rear end before , its not just bolting parts together there is a lot to it . Unless you have the tools and know how its best left to a pro. If the gears are not set up right they will not last long. JMO
Old Feb 12, 2011 | 05:00 PM
Jigger2020's Avatar
Jigger2020
If you plan on using the same gears then it's fairly easy to change the posi case....
Old Feb 13, 2011 | 02:05 AM
broncoformudv's Avatar
broncoformudv
Originally Posted by phillies4752
You will love it! Just watch it in the snow, I have heard that it can send people into the ditches
Its your right foot that sends you into the ditch not the limited slip!
Old Feb 13, 2011 | 03:55 AM
npccpartsman's Avatar
npccpartsman
I love mine. You almost don't know it's there until you need it, but it can get you a bit squirrely on slick pavement if you're right foot is a little heavy.
Old Feb 13, 2011 | 08:23 AM
Rusty Axlerod's Avatar
Rusty Axlerod
My first thought too Wulfman, but then I got to thinkin, some of my favorite past projects have been where I was "over my head" and learning stuff so that being said,,
Theres alot of info on the web about how to do this on many different vehicles and from what I'm seeing most guys are pulling the carrier, swapping the existing ring gear and bearings to the new carrier, and dropping it back in with the existing shim set-up EXACTLY as they came out and having no problems. Not even disturbing the pinion. Just a quick dye check of the contact pattern to verify everything's ok and button it up.
If it goes like that for you great, but what if the dye check shows a problem? Now you need a dial indicator, micrometer, some math skills, more shims and small parts, patience, and maybe a buddie you could call that has experience.
So I guess the answer to this question depends on what skills you have and how lucky you feel. Another option may be to swap the whole assembly, Just U-bolts and brake lines and a in few hours you are back on the road. 2WD anyway.
