Sputtered to its death.
Driving down the road and the truck starts sputtering and then dies. Wong start. I'm waiting on the tow now, but I'm curious what to be thinking about?
226k mi. Stock 7.3 psd. First warm day above freezing this week (in TX!!). Did my injectors finally take a dump? Bad diesel?
Yes, start with the basics first. Check Engine light on? Chances are all your injectors don't die at once. We can walk you through some diagnostics. Don't let a dealer snowball you if that's where you are towing it to.
i did not know that grant i know it made it easy for me this last time my cps went i was still rolling with trans in gear at tach went to 0 . so iguess from 99 -02 no tach rolling or cranking bad cps. thanks for setting me straight.
Yeah it went to the dealer. Wait to start light yes, CEL - no. I hear fuel pump when turn on to warm the plugs. Batteries/Alt - I'm thinking are ok because it has juice to try to crank. It almost turns, but won't get there.
Just had oil change last week and havent noticed any puddles but usually only check once a month. The fuel was low, I was on the way to tank up. Tried to get fuel last night but the pump was going real slow like it was malfunctioning. I would've towed it home but I work all weekend (LEO) and won't have time to bang on it.
Also - the dealer said my dust seals were worn on my front hubs. If need be, I could yank the axles and swap them out. If it is recommended, I will, but the stealer wanted upwards for $550 to do it.
They also said it's time for new shocks...oh the temptation....
