rear end swap
Old Mar 11, 2003 | 11:53 AM
82F100PU's Avatar
82F100PU
Question rear end swap
need some info please
will the 3rd member from 79 150 v8 auto trans be a direct swap to an 82 f100 I6 4sp?
if not could the entire axle be a direct swap?
i have a chance to get one at a rediculous low price and if it fits i could get rid of the 2.74 i currently have in the f100
help please.....
thanks
Old Mar 11, 2003 | 08:07 PM
ecarter50's Avatar
ecarter50
rear end swap
Yes if they both have the same axle spline count (28 or 31). Yes the entire axle will fit but will have 5 on 5.5 lug bolt pattern.
Old Mar 11, 2003 | 09:23 PM
Franklin2's Avatar
Franklin2
rear end swap
See if I am thinking correctly:
If both are 9 inch rears(smooth on the back, bolts on the front), and the 79 was a 31 spline axle, he could use the 31 spline pumpkin in a 28 spline rear if he swapped the spider gears.
I am thinking you can go 31 spline gears to 28 spline gears, but you can't go in reverse order because the hole in the 28 spline carrier is too small for the larger 31 spline axles. But I did have a machine shop tell me they can machine the hole bigger to fit, and they did it all the time.
Old Mar 12, 2003 | 04:53 AM
82F100PU's Avatar
82F100PU
Thumbs up rear end swap
to: ecarter and franklin THANKS
at least i now feel like i'm not chasing rabbits!
