Ignition, PCM ?
Old Feb 11, 2011 | 07:56 AM
Budd Schardt's Avatar
Budd Schardt
Post Ignition, PCM ?
My 2006, 4.2 has been really eradically not starting. Turns over fine ,but will sometimes fire up and tries to run on maybe 2 cylinders, then stalls. Now it won't even do that, nothing. No check eng light or codes. Guess what the thing started up this mornig 7 degrees out and running like a charm.turned off and nothing again. Replaced relay for PCM ,no change, still no codes.
Old Feb 11, 2011 | 07:29 PM
Greg B's Avatar
Greg B
I would follow the diagnostic routine in the Ford or comparable Powertrain and Emissions manual under the symptom or condition (no start). There are so many possibilities. That is the easiest and quickest way to get it fixed right. It's also the least expensive way as you won't be throwing parts at it and hoping that will fix it.
Old Feb 11, 2011 | 07:36 PM
Wilber15's Avatar
Wilber15
check the fuel pump driver module. It is mounted to a cross member right in front of the spare tires. Lower the spare and check for corrosion between the cross member and the module. They crack and fail.
Old Feb 11, 2011 | 07:57 PM
Budd Schardt
Thanks Wilber 15, will do that tomorrow. I have sprayed carb cleaner into the intake and no fire though.
Old Feb 11, 2011 | 08:11 PM
Wilber15's Avatar
Wilber15
You can check to see if the coils are firing by disconnecting one of them and installing a test light across the 2 terminals of the wiring harness. Crank the engine and watch for the test light to flash. Same thing for the injectors. If both are ok, I would suspect fuel.
Old Feb 11, 2011 | 08:40 PM
Budd Schardt
Thanks will do that. Started this 5 months ago but not as bad. would turn over and no fire then 20 secs later it was fine. Happened maybe once a month, thought no big deal.
Old Feb 12, 2011 | 03:01 PM
Budd Schardt
Wilber, you had it right. The FPDM is cracked in half. Is there any cushioning for these things ? Full of salt and dirt, I cant believe it worked at all. Im going to put some foam underneath it and some rubberwashers on the bolts. Does that sound ok ?
Old Feb 12, 2011 | 07:02 PM
Wilber15's Avatar
Wilber15
The new one will have a stud you install first then put the module on. this will lift the back of the module off the frame. you won't have any further problems....
Old Feb 12, 2011 | 07:03 PM
Wilber15's Avatar
Wilber15
don't go aftermarket. buy the ford oem module and it will have the stud kit. you'll be good to go then!
Old Feb 12, 2011 | 07:16 PM
Budd Schardt
Gotcha, and that is what I did ,though I didnt know they had a fix included, cool ! Thanks a million .
pipeline operator
13
Jan 13, 2013 10:10 AM
Iantiler
1983 - 2012 Ranger & B-Series
13
Apr 16, 2011 10:37 PM
Chips2000
18
Jun 4, 2009 05:52 AM
dsss
Jun 18, 2008 04:03 PM
Rino Onir
Nov 10, 2007 11:20 AM
