99 f350 glow plug problem?
Old Feb 10, 2011 | 05:37 PM
kerrys99f350's Avatar
kerrys99f350
Hi, Well I figured my 99 f350 7.3 was due new glow plugs since, its been hard starting for a while. I pulled all 4 plugs on the right bank and all were dripping with oil... Is that normal? should there be oil in the holes where the glow plugs screw in? If not maybe thats why I have to plug it in every night... thanks, kerry
Old Feb 10, 2011 | 05:52 PM
damicofuel's Avatar
damicofuel
They do get bathed with oil from the valve trane, so when you pull them out they will get oily. Did you ohm them out?
Old Feb 10, 2011 | 06:07 PM
kerrys99f350
Whew......Thanks for your help. No I did'nt ohm, not sure how to do that. Must admitt the old ones looked very good. Not broken or worn in any way.
Old Feb 11, 2011 | 10:03 PM
F350-6's Avatar
F350-6
If they're still in the engine you can ohm the tip against battery ground and look for a reading of less than 2 ohms. If you've already pulled them, place the black lead on the threads and the red lead on the side the wiring plugs onto and look for the same ohm reading.
Do not install Autolite brand glow plugs in your motor. The tips tend to swell up over time and break off in the head.
Old Feb 12, 2011 | 08:27 AM
kerrys99f350
Thanks for helping me. I'll ohm the left bank before replacing them. kerry
Old Feb 12, 2011 | 09:45 AM
Kwikkordead's Avatar
Kwikkordead
Why not just get a piece of wire and test them since they are out now?
It's easy. ground the threaded body of the glow plug with the wire and touch the positive post of the glow plug to the positive post of the battery, taking great care not to touch the business end of the glow plug because it will get red hot in 5 seconds or less.
This page might help. I googled it up.
http://www.turbocompressori.net/glow_plugs.htm
Kerry Helton
2004 - 2008 F150
Aug 5, 2016 09:46 PM
67camaro
15
Jul 9, 2016 11:12 AM
GlennSwett
144
Mar 13, 2014 11:08 AM
olyellow
Mar 28, 2013 08:40 PM
kerrys99f350
General Diesel Discussion
Jul 2, 2010 07:16 PM
