6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Massachusetts Drivers BEWARE!
Old Feb 15, 2011 | 06:01 AM
  #31
slowmans's Avatar
slowmans
Originally Posted by SUPERDUTY_08
I know...i was saying be thankful they dont make ALL trucks do this inspection....we would go from a $29 inspection to over $100 an inspection. But you never know what MA will do in the future... remember what a big deal is what for all the inspection stations to get the dyno's for the inspections? and a couple years later...where are those dyno's? Oh Massachusettes.....
I hear ya.....its ridiculous!
Old Feb 15, 2011 | 03:38 PM
  #32
fg250's Avatar
fg250
Originally Posted by BIGKEN
Gotta love the MASS DOT/RMV..."Department of Revenue Enhancement"!!!
I don't suppose it's any better in any other states!!!
Actually, short of california, that's the worst regulations I've ever heard of. In New York,(which has more than it's share of stupid laws) there is no emissions test for these trucks to be inspected. No dpf, no problem! I guess we are lucky for now... although I'm sure it's just a matter of time.
Old Feb 15, 2011 | 03:57 PM
  #33
BIGKEN's Avatar
BIGKEN
Originally Posted by slowmans
This only applies if you have commercial plates...
In MA...commercial plates are required if there are more than 4 wheels on the ground...or...if the GVWR is 10001 LBS or more. I wonder why the same rules don't apply to RVs???
Old Feb 15, 2011 | 07:51 PM
  #34
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
Cuz they're not making money... they're having FUN!
Old Feb 17, 2011 | 01:29 PM
  #35
jimd1050's Avatar
jimd1050
Final Update...
From my Dealer:
Thursday - 5:30 PM - Worked with National Service all day and final determination was "Replace DPF"! ???
Friday - 12:30 PM - Replaced DPF - test drove for approximately 1.5 hours - different speeds and roads - NO ERRORS!
O.K., I've seen some pretty weird solutions in my years in the Medical Electronics field but this one still doesn't seem to make sense. Truthfully, I don't care - it's FIXED! I'm picking it up this evening... thanks for everyone's concern and good wishes! Later...
Old Feb 17, 2011 | 07:48 PM
  #36
slowmans's Avatar
slowmans
my gvwr is 11,400 and I have passanger plates, I also had pass. plates on my 06 350- 11,000 lbs.....I dont use my truck for work, therefore I dont need commercial plates.
Old Feb 17, 2011 | 07:50 PM
  #37
senix's Avatar
senix
Originally Posted by jimd1050
From my Dealer:
Does not make sense but at least it is working and you have a brand new DPF too. Did it regen yet?
Old Feb 17, 2011 | 08:06 PM
  #38
jimd1050's Avatar
jimd1050
New Flash is Old Flash...
No Regen yet but it's only got maybe 35-40 miles since install complete. The tune is definitely fixed now - the "Traction Control Light" is out, it's got genuine Turbo Lag and it just plain feels STOCK again.
As for the Super Flash, it's really just an existing one.. I'm not sure what all the talk of "Latest and Greatest, soon to be released" was? They gave me the Customer Info Sheet and it says Flash 09-16-9 and in the text on my Invoice, it says the same:
"CEL On - Tested and Retrieved Code 2263 - Performed TSB 09-16-9, Re-calibrated PCM and I/C"
The DPF troubleshooting shows the following and proves their point too:
"Called Tech Hotline and was instructed to monitor DPF Pressure PID at Idle and WOT - At Idle, DPF PSI was 1.2 - Should be no more than 1.0 - At WOT, DPF PSI was 8 - Should be no more than 5-6 PSI - Per Tech Hotline, replaced DPF due to restriction, performed DPF Reset Procedure and cleared Codes - Retest was O.K. - Test Drove - no further codes"
I owe a sincere thank you to the gang at Metro Ford for their effort in getting this fixed!
Old Feb 17, 2011 | 09:03 PM
  #39
smotrs's Avatar
smotrs
That's just weird Jim. Glad it's finally taken care of.
Old Apr 24, 2011 | 01:48 PM
  #40
bushman134's Avatar
bushman134
democratic peoples republic of massachusetts
Old Apr 24, 2011 | 02:46 PM
  #41
StanleyZ's Avatar
StanleyZ
I did a quick check this morning and we have room for 5 more yankees in the ATL. Y'all better hurry. No DPF required.
Danner717
Aug 13, 2015 09:14 PM
Chevy_Eater
32
Jul 24, 2015 12:12 PM
flare-f150
1997 - 2003 F150
Jul 20, 2015 06:42 PM
K10A
Modular V8 (4.6L, 5.4L)
Jan 19, 2014 08:41 AM
imper
Feb 24, 2010 06:42 PM
