High idling
Old Feb 10, 2011 | 01:17 PM
clmiller8's Avatar
clmiller8
High idling
I have a 1995 f150 with a 351 windsor that idols at around 2500-3000 rpms and ive replaced the egr valve and the high idling sensor and it still didnt fix the problem. I dont know what else to even look for. Anyone else had the same problem and fixed it?
Old Feb 10, 2011 | 04:29 PM
SilverSport's Avatar
SilverSport
Check all over for vacuum leaks. A big one could raise the RPM that much. Someone here last week reported finding a leaky intake gasket on his truck that was very similar year and engine to yours.
Old Feb 11, 2011 | 01:23 PM
otrawj's Avatar
otrawj
I have the same problem but idles ok after unplugging control valve. If a leak I think it would idle hi always ??????
Old Feb 15, 2011 | 08:19 PM
clmiller8's Avatar
clmiller8
Actually i took it to the shop and it ended up being the ECM (electronic control module). Its on the left fenderwell and the guy said after a while the water from the wheel gets in there and ends up tearing it up so i hope it helped.
Gmeanie
Jul 20, 2014 12:45 PM
doormansamaniego
Dec 12, 2011 02:06 AM
oldfordisbetter
Jan 1, 2011 09:23 AM
Bert2
1983 - 2012 Ranger & B-Series
Jun 11, 2004 08:54 PM
