Door Lock Help
Old Feb 10, 2011 | 11:01 AM
emgee's Avatar
emgee
Question Door Lock Help
I'm going to be fitting 1992 doors into my 1980 F100. The '92 doors have push/pull locks and a round lock cylinder. My '80 doors are slide locks with round lock cylinders. Can I re-use the '80 cylinders in the '92 doors? The '92 doors are from a JY; there is no key for them. Am I better off just getting new locks for the newer doors?
Old Feb 10, 2011 | 12:18 PM
Harfend's Avatar
Harfend
My LMC catalog shows the attachment lever on the back of the lock cylinder is different between 1980 and 1992. I dont know if the arm could be swapped but it should be easy to determine once it is removed and in your hand. BTW, a new door lock set for a 92 door with keys is about $60. Your call!
Good Luck!
HARFEND
Old Feb 10, 2011 | 02:40 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
According to the parts books they are different and won't work.
