backwards swap
Old Mar 11, 2003 | 08:47 AM
knarf's Avatar
knarf
Question backwards swap
I want to swap out the blown 302 in my 1991 f-150 with an overdrive automatic tranny with an in-line 6 from a 1988 150. Can I do this and keep the automatic tranny or will I also need to switch to the 4 speed that is with the 6?
Old Mar 11, 2003 | 09:31 AM
mantta's Avatar
mantta
backwards swap
The bolt pattern is the same. You can use either transmission.
Old Mar 11, 2003 | 08:36 PM
ecarter50's Avatar
ecarter50
backwards swap
Get a flexplate for the 300. Do not use the one from the 302. They are balanced differently.
Old Mar 12, 2003 | 04:02 PM
knarf's Avatar
knarf
backwards swap
I heard that flexplate diameter is different between the two motors. If so will the starter position from the 302 tranny work with the new plate?
Old Mar 12, 2003 | 05:47 PM
ecarter50's Avatar
ecarter50
backwards swap
300 and 302 flexplates are the same except for the weight welded on for the 302.
