Need help/ question
Old Feb 9, 2011 | 10:34 AM
nates78's Avatar
nates78
Need help/ question
Im replacing my 1 barrel carb to a 2 barrel, along with a new intake. while im doing this, i was wondering if it would be possible to take off the air quality control part, that that is between the intake and the carb( sorry i have no clue what this thing is called). I live in Tennessee and its the only state that doesnt require this part to be on vehicles. could some one please tell me what this part is called, and how to remove it?? THANKS
-Nathan
Old Feb 9, 2011 | 11:24 AM
AbandonedBronco's Avatar
AbandonedBronco
Does it have a pipe coming from the rear of the exhaust manifold and up into this part you're talking about?
If so, it sounds like you're talking about the EGR spacer / EGR Valve.
IF you're able to, that's one of the few emissions parts that can actually increase performance/gas mileage. So if you don't need to remove it, and it's working, leave it be.
If not, though, just remove the pipe from the exhaust manifold, plug it up, and then remove the EGR spacer.
What intake are you installing?
Old Feb 9, 2011 | 03:28 PM
Wyowanderer's Avatar
Wyowanderer
-Nathan
You CAN take it off, but like AB said, it's the most important part in your emission system. It lets inert gas (exhaust) into the intake, which cools the combustion temp and allows you to run more timing, which gives more power and increases power.
If you replace the carb AND intake, you'll have to remove it, but it won't matter, since the new carb will need rejetting anyway.
Old Feb 9, 2011 | 04:50 PM
nates78's Avatar
nates78
thanks guys. i am installing an offenhauser intake, with a Holley 500 2 barrel. so i may HAVE to take it off.....
and what do you mean by re jetting?
Old Feb 9, 2011 | 05:00 PM
AbandonedBronco
Ah, if that's the case, you won't be able to use it without some serious, serious work.
Just remove the pipe and plug the hole in the exhaust manifold. The EGR spacer / EGR valve won't fit onto your new setup anyway.
Old Feb 9, 2011 | 07:13 PM
nates78's Avatar
nates78
will it make the motor to hot without it? and i knew i would have to plug the hole, if i took it off. any suggestions for plugging it? I appreciate all your help.
Old Feb 9, 2011 | 08:01 PM
AbandonedBronco
No, about the most it'd do is possibly making it ping under heavy load with the stock carburetor, and make it run lean.
With an aftermarket carb and intake, you won't have any issues.
As for plugging it, IF you can get it out, take the pipe down to a plumbing store and match it with an end cap. I got one for mine for less than a dollar. Most likely, though, its so rust welded in there that it may be easier to just cut the pipe, fold it over, and weld it (or have it welded) shut.
Old Feb 9, 2011 | 08:13 PM
AbandonedBronco
Most carburetors will need to be calibrated to your engine's specific needs.
Many of them have different jets you change swap in and out. If your fuel mixture is too lean, you re-jet and install a jet with a larger hole (allowing more fuel to pass through to richen up the mixture). If the fuel mixture is too rich, you re-jet with jets with a smaller hole to reduce the amount of fuel.
If you don't know, and plan on swapping in aftermarket carburetors, I'd definitely recommend reading up on how to properly tune a carburetor, or you may be bolting on a headache.
It's fun (and rewarding) to do. But it takes some learning.
