4 wheel drive help
Old Feb 8, 2011 | 08:26 PM
danny2313's Avatar
danny2313
4 wheel drive help
i have a 2004 f-250 6.0 kr 4x4. we have recently and again tonight had snow in east texas and my 4 wheel drive doesn't work. i have read all the threads and looked through the spreadsheets on here and got some good help, but here's what is happening. i can put the switch in 4x4 high and check vaccum to each side at the hub. i have great vaccum for a second then it dies. i have isolated each side and checked them by their self and i show no leaks. i have not checked it with a gauge. but i do have great vaccum to each side individually with my thumb over the line. could the vaccum switch be going bad? the pump comes on and runs about 2 minutes before it shuts off. with everything hooked up right and in 4x4 high i can still turn the front axle. thanks.
Old Feb 8, 2011 | 08:34 PM
Zmann's Avatar
Zmann
?? leaks can be in the HVAC system and front hubs ,,
Old Feb 8, 2011 | 10:01 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
I don't think that continuous vacumm is supplied to the hubs...only a pulse that causes them to engage and disengage. I might be wrong (would not be the first time) but I remember reading that here on the forums somewhere. Possibly the hubs are just "gummed up" or there are leaks at the hubs themselves. Twist in the hubs manually and drive them around for a while...then twist them out to "auto" and see if the ESOF will work then. Do a search or check the tech folder...or maybe someone else who knows for sure will post.
Old Feb 9, 2011 | 01:25 AM
broncoformudv's Avatar
broncoformudv
I have been wondering that and keep meaning to check it out on mine. My hubs like to come unlocked when most needed so I just leave them manually locked in instead of relying on the ESOF. Need to figure it out and fix it at some point but keep getting side tracked with other issues like head gaskets, seat heater, etc.
Old Feb 9, 2011 | 01:39 AM
Bonanza35's Avatar
Bonanza35
Smile
You don't have continuos vacum. If they are not staying engaged the seal on the hub itself is leaking. You will need to take the hubs off and apart to replace the seals. Before you do this you can test each hub with a vacum gauge to see if the seals are failing. Good luck
Old Feb 9, 2011 | 04:50 AM
F-250HD's Avatar
F-250HD
As the previous poster said, the vacuum pulses, 45 seconds to engage, I think 20 seconds to disengage. Your easiest recourse is to manually lock the hubs in by turning them clockwise until they stop, counterclockwise when 4WD is no longer needed. 4wd will still engage and disengage with the switch. My hubs work great, my truck is just crotchety engaging 4X4 while moving.
John
Witty73
15
Oct 20, 2010 10:35 AM
wildwheelerb200
Apr 4, 2010 12:08 PM
woody24
2004 - 2008 F150
Oct 5, 2008 08:22 AM
scoop75
1997 - 2003 F150
Sep 14, 2008 10:57 PM
plumr
Mar 16, 2002 11:54 AM
