92 Fuel pressure problem
Old Feb 8, 2011 | 05:07 PM
Slip ford man's Avatar
Slip ford man
I had another thread going on for this problem, but it was titled indicating a code solution was sought, it is a fuel delivery problem. I determined that this is a fuel problem, and maybe someone with knowledge of fuel systems can help me out here. Link to original thread:
https://www.ford-trucks.com/forums/1...led-motor.html
Well the truck finally repeated the problem today. I've been driving around since the problem first occurred with a fuel pressure gauge hooked up to the rail. When she died I looked at the gauge and it was at 30 psi, 5 psi below minimum spec. I waited a half hour turned the key to get a reading, the gauge said 32 psi, again this was engine off. It was enough to start her, so I continued to the gas station. After fueling, I took another reading engine off, she was at 40 psi, which is normal. So now the question, dose this indicate the fuel pump motor is getting to warm and dragging, and not able to deliver the needed 35 to 45 psi?, or possible something else is going on here. There is no pump on the frame rail, did the 92's have their fuel pumps located only in the tank's?
Old Feb 8, 2011 | 09:56 PM
rla2005's Avatar
rla2005
You have a single high pressure pump in each tank. If the fuel pressure is dropping then I would suspect the Fuel Pressure Regulator. If the pressure drops on each tank, it is either a weird fuel filter problem or more likely the FPR.
Another thought would be the fuel pump relay getting resistive when hot. There would be more of a voltage drop across the contacts therefore less voltage getting to the pumps. It is a long shot, but a possibility.
Start with the pressure regulator, then go from there.
Old Feb 9, 2011 | 09:09 AM
Conanski's Avatar
Conanski
Check that the pumps are getting a steady 12v first, look for corroded or frayed wires at the relay and inertia switch. You could take the monitoring a step further and wire in a volt meter at the tank to see if the voltage drops when the problem occurs. If it doesn't then that would tend to indicate a failing pump or clogged fuel filter, and while the FPR could be bad they generally don't fix themselves after going bad so that's not as likely.
Old Feb 9, 2011 | 09:45 AM
subford's Avatar
subford
Does not sound like a fuel problem.
Sounds more like an Ignition problem.
It is normal for the fuel gauge to drop to about 30 PSI as the engine dies.
The engine should keep running down to about 28 PSI.
I would look at the PIP sensor or the TFI module.
After reading your other post.
You did not seem to have a code for the fuel system or PIP so I would guess a bad TFI Module.
Old Feb 9, 2011 | 10:37 AM
Slip ford man
Thanks for the help...does a TFI cool off and cure it self, till the next heat up?
Old Feb 9, 2011 | 10:52 AM
subford's Avatar
subford
Yes it can.
Old Feb 9, 2011 | 11:08 AM
BRay09's Avatar
BRay09
yeah even if you take a bad TFi to the parts store and have them check it they will tell you its in good shape lol. The thing is they go bad when they are hot and they have no way to be able to heat them up at the store so they only test it cold.
Old Feb 9, 2011 | 11:54 AM
subford's Avatar
subford
I take it your fuel pressure gauge is doing something like the one in the attached FLV video.
Just click in the image.
Old Feb 9, 2011 | 01:33 PM
Slip ford man
No thank god...ignition off 40psi-running 34, steady. I just bought a TFI and will be installing soon. That's if I figure out what type of screw head they got in there, holding her down. lol
Old Feb 9, 2011 | 02:11 PM
BRay09's Avatar
BRay09
If it is on the distributor, It needs a special tool. damn fords They have them at advanced auto or autozone. Its an ignition module removal tool
Old Feb 9, 2011 | 02:18 PM
Slip ford man
Yea I heard that, when I asked them over there, they looked at me like I was nuts lol ...I'm just wondering the head style and size, my friend says its a 5mm standard 5 sided socket ground down for side clearance. Mine is on the drivers side fender.
Old Feb 9, 2011 | 02:48 PM
rla2005's Avatar
rla2005
It's a 7/32 (5.5MM) thin wall socket. Ryan has some info here: Ford Fuel Injection » EFI Tools
Old Feb 9, 2011 | 02:59 PM
Slip ford man
Thanks ria!!! I have a couple of them, I'll grind one down a bit.
Old Feb 13, 2011 | 04:12 AM
Slip ford man
Update-- TFI module was the problem, thanks all.
milehieagle
31
Apr 24, 2021 06:26 AM
rexpedition99
Mar 6, 2017 10:17 AM
96F150-4.9
Sep 26, 2016 12:08 AM
Baatzy
70
Mar 17, 2016 12:05 PM
fast2174
Sep 17, 2010 12:12 PM
