1978 - 1996 Big Bronco
ok I need help
Old Feb 8, 2011 | 11:31 AM
russler43's Avatar
russler43
ok I need help
This may sound like a stupid question to some,but I am trying to wire a starter switch to the solenoid.The reason I'm doing this is because,on my 91 Bronco inside the steering column the rod that pushes the starter switch down has striped.It still turn to the start position and every thing works but I have to jump the solenoid with a screwdriver.I have tried to wire just across the two big terminals with a switch like I'm jumping it with the screwdriver but that didn't work.Am I wiring it wrong and if so can some one help me?
Old Feb 8, 2011 | 12:47 PM
Joseph69's Avatar
Joseph69
Old Feb 8, 2011 | 02:53 PM
greystreak92's Avatar
greystreak92
Watch posting links to competing sites.. admin. isn't too keen on it.
The column actuator can be replaced and the procedure has been detailed here many times. The ignition switch closes contacts for five separate circuits when engaged so it cannot simply be bypassed with a pushbutton. The contacts are also engaged incrementally to that certain circuits are energized before the actual start solenoid is triggered. The EEC-IV power relay (main computer power), the fuel pump relay, and the ignition SPOUT signal relay are just a few of the devices that are energized when the switch is engaged.
Old Mar 12, 2025 | 06:08 PM
Brad gib's Avatar
Brad gib
1st Gear
Spoiler
Old Mar 16, 2025 | 04:06 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Brad gib
Spoiler
I’m not sure if you realized it but the last post in this thread was 14 years ago.
neradk
13
Sep 17, 2023 09:18 PM
swing
Jul 12, 2023 12:34 AM
mattb77
Oct 21, 2016 12:37 PM
77-400-4x4
Mar 13, 2007 06:37 PM
Frankenstang57
Oct 10, 2005 09:43 AM
