Rotella T
Old Feb 10, 2011 | 11:47 AM
76F100guy's Avatar
76F100guy
Bob Is The Oil Guy
Old Feb 10, 2011 | 07:13 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Mobil 1 10w-30 FTW! Go synthetic in the tranny and differential(s) too.
Old Feb 11, 2011 | 10:17 AM
Harte3's Avatar
Harte3
The most neglected parts of the power train...tranny and differential. X2 on the synthetics.
Old Feb 11, 2011 | 11:09 AM
Derrick lane's Avatar
Derrick lane
Already did the trans,t case,front dif rear dif per owner manual.
Old oils were clean. Motor oil was changed by PO when i got the
truck i put in some marvel mystery oil and have Ben running with
that for 800 mi.
Trying to figure out what would be best to put in it now.
FTW ????
thanks
Old Feb 11, 2011 | 07:22 PM
BaronVonAutomatc
Mobil 1 10w-30 For The Win!
Old Feb 11, 2011 | 07:31 PM
Opossum's Avatar
Opossum
I use the Rotella T6 5W-40 synthetic in my high mileage 460 (no idea how many times it's turned over)
Old Feb 12, 2011 | 10:00 AM
Derrick lane
good or bad
As stated I ran it with the clean PO oil for 800-1000 mi with some marvle mystery oil in it.
Changed it with rotella t 15-40 and a pre filled napa gold 1515 last nite.
Let the truck run back up to temp, oil pressure gage stayed about the same as
normal , half way between low and centered.
Went for a ride 15mi and noticed the gage was half way between center and
high I've never seen the oil gage that high before, engine was not making any extra noise.
"Is this a good or bad thing ?"
Would a oil passage of goten blocked causing a higher pressure reading.
If so could compressed air thru the oil sending unit hole possabley un block the
passage?.
Any thoughts much appreciated
Old Feb 12, 2011 | 10:54 AM
redrivergorge's Avatar
redrivergorge
The factory oil pressure gauge doesn't read exact pressure only if theres 7psi or not. I don't know why they flucuate mine does too.
99ExpyProblems
6.7L Power Stroke Diesel
Oct 12, 2013 01:04 PM
99ExpyProblems
Oct 7, 2013 07:40 PM
ATX F250
6.4L Power Stroke Diesel
Apr 8, 2012 01:33 PM
fatcowvtx
Nov 13, 2010 10:30 AM
Trakk
Oil & Lubrication
May 21, 2005 09:46 PM
