Sponsored by: Real Truck
2011 Transmission Shift Question
Old Feb 10, 2011 | 06:29 PM
loganworks's Avatar
loganworks
The slipping or as I refer to it the dead zone has been a common problem with the 2nd to 3rd shift. Ford has updated the software and the PCM needs to be re programed. It sounds like they screwed up while doing it. There have been quite a few on here that have had this happen. I need to have it done also and are waiting for my first oil change do so and hope that my dealer is able to do so without frying my PCM. Hope that you get yours up and running again soon.
Old Feb 14, 2011 | 12:42 PM
Firewiz's Avatar
Firewiz
Well it's good (and bad) tah hear that other peeps encounter that 5th gear rpm drop. I have not had anymore instances of it slipping going from 2nd to 3rd, and I am taking the advice on the rpm drop in 5th @ 40mph as its the torque converter. Thank so much all.
Old Feb 24, 2011 | 04:01 PM
real_texan's Avatar
real_texan
Well it has gone from bad to worse. They fried the new pcm. They are ordering another one again. This time they were instructed not to use the newest update and that should fix. We shall see.
Old Nov 17, 2011 | 05:18 PM
Yob2kanobe's Avatar
Yob2kanobe
2-3 shift probs
Ive go the dreaded 2-3 shift slip on my 2011 F250 gasser especially when its cold. Any more input on this? did the PCM update cure this?
Old Nov 17, 2011 | 05:57 PM
satxuser's Avatar
satxuser
The PCM reprogram did solve my issue 99%. Once in awhile I will feel a small delay when shifting from 2nd to 3rd, but nothing like it was before the reprogram.
Following is how my service ticket was written when I had the work done in July. Wording seemed to be important to the service guy.
P66 CUST STATES HAS FLARE WHEN SHIFTING FROM 2ND TO
3RD GEAR
REPROGRAM PCM N C
PER 11-06-11 TSB
Old Nov 17, 2011 | 06:31 PM
Yob2kanobe's Avatar
Yob2kanobe
wow thanks. I will print that and give to my ford stealer. Other wise I love the truck, the 6.2 has plenty of power. Im at 35000 miles. thanks again
Old Nov 17, 2011 | 08:15 PM
niffty 350's Avatar
niffty 350
Hello fellow Forders, I stumbled on to this sight looking for some help.
I am having issues with 2nd to 3rd shifting on my 11 350 W/6.2. Took it back to the dealer and they reprogrammed the PCM. Lasted about 2 weeks before it started to act up again. I talked to the service manager to see what he thought could be done. He told me that he would call Ford to see if there was something else to try. As of this afternoon he had not recieved a reply. Any help would be welcome. Thanks!
Old Nov 17, 2011 | 08:22 PM
Quad Racer's Avatar
Quad Racer
I have an 08 and have occationally noticed what I'd call a hard shift kinda whats been described between 2-3 gear. To me it felt like a torque converter grabbing since it was in low RPM. If you hammer on the rig and it runs and shifts fine, it's fine. There is some play in all the moving parts of an auto trans. I'm no mechanic, but I have mechanical aptitude and it seems "normal" to me.
Old Nov 17, 2011 | 08:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You should start a new thread. Your transmission is not anything like the newer ones. What fixed theirs will not work on your transmission.
Old Nov 17, 2011 | 08:50 PM
Yob2kanobe's Avatar
Yob2kanobe
Great,,, let us know what you find out..
Old Nov 17, 2011 | 08:59 PM
Quad Racer's Avatar
Quad Racer
I wasnt sure if it was. To be honest I'm not overly concerned with it. Just something I felt "seat of the pants" occationally. I have a warranty so if I notice a persistant problem I may take it in. Ive only noticed something maybe 2 times in 6 months. Thanks for the heads up.
Old Nov 18, 2011 | 05:31 AM
2000silverbullet's Avatar
2000silverbullet
Depending on the build date of your truck, there's 3 solenoids that need to be replaced as well. Did yours require this, and if so, was it done by the dealer? There has been a couple of 6.2 owners that never seemed to have their trans issues resolved after applying the TSB, haven't heard any updates from them but there's a long thread down in the 6.2 forum about the transmission.
Details of the TSB below.
File Type: pdf
Old Nov 18, 2011 | 06:46 PM
  #28
niffty 350's Avatar
niffty 350
Silverbullet,
Thanks for the info!!! I passed it along to my dealer today. I will make an appointment ASAP to get it in to the doctor. The truck was built on 9/10 and they did not replace those solenoids when it was in before. I will let you folks know how I make out. Thanks again!
Old Dec 8, 2011 | 05:56 PM
  #29
niffty 350's Avatar
niffty 350
Trans. fix update.
I got my 350 back from the Doc today. They swapped out the three solenoids and reprogramed the computer. We'll see what happens!!!
Thanks again Silverbullet for your help!
Old Dec 8, 2011 | 09:37 PM
  #30
2000silverbullet
Good deal, hope it fixes the problem.
