axle code???????
Old Mar 10, 2003 | 08:48 PM
rustyolred27's Avatar
rustyolred27
axle code???????
my axle code on my door is 16. what does that mean? from my research i think i have 4.10 gears with some kind of traction aid. does the axle code indicate this or was it added later? my truck is a 1981 f-150 4x4 300 i-6, np435 4spd and a np208 t-case.
Old Mar 10, 2003 | 11:26 PM
TallGuy_Az's Avatar
TallGuy_Az
axle code???????
While he is asking, I have the same exact truck only the axle code is 14. Anyone know what I have?
Old Mar 10, 2003 | 11:37 PM
steve83's Avatar
steve83
axle code???????
"1" in the first position generally means an open differential. "H" ,means limited slip. 14 is a 9" with 3.00 gears, but I don't know about 16. It could be 4.10s.
Old Mar 11, 2003 | 08:03 PM
rustyolred27
axle code???????
btw the metal tag on my axle says 3L55. so it originally came with a limited slip and 3.55 gears right or could this just be another thirdmember that was added with the 4.10 gears?
Old Mar 11, 2003 | 11:51 PM
steve83's Avatar
steve83
axle code???????
16 is NOT the code for 3.55 L/S (which is what "3L55" means), so that 3rd member has been swapped. You'd have to roll-test it to find the actual ratio.
Kyle Wood
Oct 19, 2016 11:28 PM
Musicims
17
Mar 21, 2016 07:27 PM
pinn600
Large Truck
Apr 2, 2012 05:50 AM
keyul
23
Sep 14, 2009 11:05 PM
catmandu79
May 11, 2004 07:09 AM
