water pump replacement
Old Feb 7, 2011 | 02:15 PM
ctcoxfamily's Avatar
ctcoxfamily
Just got a 1965 F-100. I need to replace the water pump. Short of cutting the fan shroud in half to make it easier to remove does anyone know of a better way to remove it?
Old Feb 7, 2011 | 03:00 PM
chaser1602's Avatar
chaser1602
UH, remove the fan first?
Old Feb 7, 2011 | 05:03 PM
thechief66's Avatar
thechief66
Wow, I never had one with a fan shroud.
Old Feb 7, 2011 | 05:11 PM
bertha66's Avatar
bertha66
My 55 does not have a shroud, but my Bronco does, to get the fan off it, you have to take the fan loose and then take the fan loose and remove both at the same time. If you have a 66 with a shroud, that is way cool.
Old Feb 7, 2011 | 06:23 PM
66f-100's Avatar
66f-100
If you even remotely considered that as a possibility, maybe you should take it somewhere if get it repaired. Tearing up one part of the truck to repair another part is less than ideal.
Old Feb 7, 2011 | 06:40 PM
Boss9F100's Avatar
Boss9F100
Remove the 4 screws/bolts from fan shroud and move it rearward so you can get at fan bolts. Unbolt fan and remove both together... Does not get much easier than that!
Old Feb 7, 2011 | 07:04 PM
ctcoxfamily
I agree. I had no intentions of cutting it in half. I was able to move the shroud to the rear and it did come out pretty well. Thank you everyone for your advice. The new pump is on and working great.
Marauder2004
Jun 30, 2014 07:17 PM
chermansr
Nov 1, 2013 03:22 PM
don58
Sep 3, 2003 09:24 AM
tfingle
1983 - 2012 Ranger & B-Series
Mar 25, 2003 06:53 AM
