Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Lightning engine swap into Excursion
Old Mar 10, 2011 | 08:58 AM
  #31
mac06gt's Avatar
mac06gt
That is what I'm saying the lightning and all super duty are beefed up but the excursion 4r100 is a grocery getter transmission only! Excursion is not super duty!!Excursionator I'll post pics and details on the swap when I get back to Atlanta next week!
Old Mar 10, 2011 | 12:24 PM
  #32
Stewart_H's Avatar
Stewart_H
In the 5.4L powered Ex, yeah.
The 7.3L powered Excursion has the beefed up "diesel" innards trans, and I THINK the V10 does too.
Stewart
Old Mar 14, 2011 | 07:57 PM
  #33
mac06gt's Avatar
mac06gt
well every thing was going fine until we went to program the pats! aparrently the lightning pats is in the pcm and the excursion pats is in the instrument cluster so they were not getting along. No injector pulse!! Had lethal performance send me a tune with pats disabled. Hope to get her running this weekend.
Old Mar 15, 2011 | 01:14 AM
  #34
phil6608's Avatar
phil6608
For any of the Ford trucks with PATS the computer, instrument cluster, key and ignition all have to match.
When I put the L computer in my truck,I did the same thing.Just turned it off so I didn't have to spend the money for a dealer to match it all up.
Sounds like you doing great!
Old Mar 19, 2011 | 09:56 PM
  #35
mac06gt's Avatar
mac06gt
After 9 days of work she is running like a champ. It sounds wicked
With the JLT intake kit on that eaton blower! I have Gibson headers
going thru a factory excursion cat and Gibson muffler so the quiet
exhaust adds to the blower whine. If I ever get a second at my home
computer I'll post pics and details.
Mac
Old Mar 20, 2011 | 12:50 AM
  #36
phil6608's Avatar
phil6608
Congrats.
Hows that power feel?
Old Mar 23, 2011 | 01:30 AM
  #37
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
This has to be one of the best swaps. Video would be nice too.
Old Mar 23, 2011 | 09:46 AM
  #38
mac06gt's Avatar
mac06gt
Finally Done!!
The power is awesome. I have to get a few codes for evap, fuel level sensor, egr, and all downstream o2 heaters off to clear all the codes. Is it true that the ecm will be in a limp mode if the service engine light is on? I cant imagine if she gets stronger with the codes cleared? I have to get an appointment for custom tune in a couple of weeks for now im just glad to be thru working on it!!!!!!! The biggest pain was the wiring from the lightning harness thru the excursion body harness to the lightning ecm. Luckily I had a X-ford technician on hand that had been to svt training ect. Mechanically the engine fit easily and everything bolted up no issues. The pain was all the other stuff custom fitting. Heatexchanger, pump, overflow, air intake, modifying hood to clear, modify cowl to clear, cut off top of throttle are to clear, cut off shroud to clear front pully bracket ect.
Well worth it.
What is the easiest way to post pics on here?
Old Mar 23, 2011 | 10:56 AM
  #39
phil6608's Avatar
phil6608
Load your pics into Photobucket site ,then copy the link under your pic and post the link here. That's the best way I know.
The codes you have wont affect your power any(limp mode). Never did in my truck and I get a code occasionally. Unless you get a (miss) code of course.
Old Mar 23, 2011 | 07:12 PM
  #40
mac06gt's Avatar
mac06gt
Couple pics of the project Ill post the whole bunch this weekenf on photobucket.
Mac
Old Mar 23, 2011 | 07:14 PM
  #41
mac06gt's Avatar
mac06gt
check out the intercooler heat exchanger fit!!!
Old Mar 23, 2011 | 07:16 PM
  #42
mac06gt's Avatar
mac06gt
Here is the pic of the planetary out of the non super duty trans. The lightning was a steel housing with 6 gears.
Old May 4, 2011 | 10:36 PM
  #43
bigrigmike's Avatar
bigrigmike
so whats the deal now
Old May 7, 2011 | 05:52 PM
  #44
mac06gt's Avatar
mac06gt
Running great! I still need to go dyno tune it because I have a couple evaporate codes, erg code, and a fuel level code that I need deleted. I am dying to see what the rear wheel hp will be? JLT cold air kit, afco huge intercooler heat exchanger, and Sct livewire tune? Any ideas from the lightning gurus?
Old Jun 2, 2011 | 11:03 PM
  #45
4trk's Avatar
4trk
wow this is a beautifull swap how much do you have invested so far I will preciate any help cause we are intetested in doing something like that too my buddys excursion just bluw up 2days ago and so this would be tje perfect time to do a swap like that thanks for any help. lol
