Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Lightning engine swap into Excursion
Old Feb 18, 2011 | 08:35 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
MAC please post pics or details on the swap. I'm very interested in doing this to my v8 ex
Old Feb 19, 2011 | 08:10 AM
mac06gt's Avatar
mac06gt
Will do I'm starting the swap on march 7th at my brother in laws shop Melton Automotive in Birmingham , AL. Does anyone know of a dyno tune shop in B-ham that can tune the excursion? If not I'll cruise back to Atlanta and hit up dynolab!
Old Feb 19, 2011 | 08:35 AM
phil6608's Avatar
phil6608
I don't think it will even run without some kind of a Lightning tune in it! So you might not be able to cruise.
Best thing to do would be go to that place you mentioned and get them to put a stock Lightning tune on a tuning devise so you can load it in your computer after the swap. Then go back and get it dyno tuned.
Old Feb 19, 2011 | 03:13 PM
mac06gt's Avatar
mac06gt
I actually found a 2001 lightning ECM for $200 so I got it for a temporary get her runnin step. What type of tuner do you recommend ?
Old Feb 19, 2011 | 04:40 PM
phil6608's Avatar
phil6608
I would go with whatever tuner the guy tuning it recommends.( some guys only tune on certain makes!)
I use an SCT-X3 from Superchips.
Old Mar 1, 2011 | 07:42 PM
mac06gt's Avatar
mac06gt
here is another question for you guys. The 2001 lightning motor and trans are sitting at the shop ( 62K on the truck before totaled) it looks like all the main plugs are on the passengers side of the lightning? My excursion has the plugs on the drivers side. Phil had said to use my haeness and just buy a tuner so I've bought a sct livewire with base lightning tunes or I could extend the harness and use my lightning ecm? Not sure which is more beneficial? Just covering all my bases!!!
Old Mar 6, 2011 | 08:00 PM
mac06gt's Avatar
mac06gt
Ran into a issue the torque converter on my excursion is a 4 bolt and the converter on the lightning trans is a 6 bolt? Should I just slap the converter from the lightning trans on my excursion trans? Or go to the trouble of taking the trans to tge shop and get the tail shaft swapped over to the lightning trans?
Old Mar 6, 2011 | 08:01 PM
mac06gt's Avatar
mac06gt
I know I could just swap the flywheel but my excursion flywheel has some chewed up teeth!!
Old Mar 7, 2011 | 12:32 AM
phil6608's Avatar
phil6608
You don't want to swap the tail-shaft. To do that the trans has to be totally taken apart and put back together. The tail shaft is the first thing to go into the trans and the last thing to come out.
Swap torque converters or buy a new flex plate.
I think there only about 45 bucks.
Old Mar 7, 2011 | 12:35 AM
fordinlinesix's Avatar
fordinlinesix
Use the Lightning TC, it prob has a higher stall than the one in your Excursion anyways.
Old Mar 7, 2011 | 06:40 PM
mac06gt's Avatar
mac06gt
So after talking to the local ford service guy he said that the excursion trans is definately different from the f250 and f350 and lightning so I'm having the trans inners swapped! 2 day set back.
Old Mar 7, 2011 | 07:03 PM
mac06gt's Avatar
mac06gt
After removing the erg system and now going to disable the boost bypass system it looks like we only have one more sensor I have no idea what it is but it has a blue o-ring on tge bottom side under the bracket. It is next to the scb solenoid? Any thoughts?
Old Mar 9, 2011 | 08:22 PM
  #28
mac06gt's Avatar
mac06gt
Glad I had the transmissions gone thru. Exc trans had 3 aluminum planetary gears and the lightning had 6 steel! That's what trans guy said? Had to basically extend and rewire the harness to the correct pins on the ECM plugin. Adding relays and fuel pump resistor tomorrow then in goes the motor!!!!
Old Mar 10, 2011 | 01:32 AM
  #29
EXCURSIONATOR1
Does that meen the exc trans is stronger built? I want to do this to mine.
Old Mar 10, 2011 | 02:00 AM
  #30
Stewart_H's Avatar
Stewart_H
Seriously? 3 aluminum versus 6 steel?
The 4R100 in the Gen 2 L's has the same innards as the diesel 4R100's, just with a different bellhousing.
Stewart
