1965 F100 Engine Swap
Old Feb 7, 2011 | 01:38 PM
runsky69's Avatar
runsky69
Hi everyone, I appologize in advance. My son has a 65 F100 with the 300/6. We have already removed it. Now we want to install the 302 with the C4 trans out of my 67 Mustang. Will it just drop in, do we need some kind of kit? Please help. Thank you in advance!
Old Feb 7, 2011 | 05:04 PM
thechief66's Avatar
thechief66
You want to get the frame perches and motor mounts from a mid 70's truck with a 302.
Old Feb 7, 2011 | 08:16 PM
garbz2's Avatar
garbz2
You will need to locate the perch. any 302 or 351M/400 Perch Is what you need.
Use stock truck 302 insulators.
You must also relocate the stock trans mount back a few inches. Just drill a new mounting hole in the lower rail.
Use a new C4 trans mount for a truck app.
Garbz
Old Feb 9, 2011 | 11:18 AM
runsky69's Avatar
runsky69
Thanks for the info.
Old Feb 10, 2011 | 03:45 PM
militos's Avatar
militos
and the Drive shaft/unirversal joints??
will they use the Truck stock one,(fits?), or the stock drive shaft will need to be re-sized and the universal joints replaced?
thanks, good Luck.
Old Feb 10, 2011 | 09:38 PM
garbz2's Avatar
garbz2
C4 from the stang will have a slip type Yolk where the Truck is a bolt on type.
Anytime a swap is preformed one has to anticipate drive shaft modifications.
Garbz
Old Feb 11, 2011 | 10:47 AM
runsky69's Avatar
runsky69
Good call. I figured that I was going to have to change something. Never that lucky.
rkhanso
24
May 15, 2017 07:59 PM
Toddw440
Feb 17, 2017 09:58 AM
Jim and Austin
16
Oct 6, 2016 05:49 PM
xeroshi
Jun 19, 2015 01:18 PM
dimarco21
Oct 12, 2007 12:27 PM
