Knocking under dashboard on passenger side?
Old Feb 7, 2011 | 10:32 AM
05truckguy's Avatar
05truckguy
Exclamation Knocking under dashboard on passenger side?
Any expert advice here would be great-
Truck-2005 F-150 XLT 5.4L
Problem-Currently when my truck reaches a speed of 45mph+ there is a methodical knocking sound that comes from the passenger side dash. This sound is on the interior and comes from the far right corner of the dashboard.(almost as if someone is tapping with there finger every other second). There is no correlation with anything else being turned on or off that affects this sound.(i.e. air) It simply happens once I reach a certain speed and is not an outside noise. When I slow back down under 45 mph the knocking subsides. Has anyone ever experienced this? Any suggestions?
Old Feb 7, 2011 | 10:54 AM
alberta46's Avatar
alberta46
It might not be inside. I had that happen on my exploder and it turned out it was the front wheel bearing.
Old Feb 8, 2011 | 02:01 PM
KyTruckPlant's Avatar
KyTruckPlant
I got the same thing, but it only seems to happen when it is really cold out. Mines a 05 FX4. I was assuming it was some trim or something that isnt as pliable in the lower temps. Its been doing it on mine for about 3 years. Instead of tearing my truck apart to find it, I just pray for warmer weather......
Old Feb 9, 2011 | 08:18 AM
05truckguy's Avatar
05truckguy
There has to be a correlation with the speed here....something is causing that knock when I reach a certain speed. It sounds almost as if the clicking is coming from right beneath the airbag. That wouldn't make much sense in regards to speed though...IPn reference to the wheel bearing idea...This sound is strictly on the interior and is unacceptable, there should be no reason that a knocking sound should happen under the dash when I go 45mph+....I'll look into this further and see what I can find.
sitiakab
1997 - 2003 F150
May 29, 2012 05:50 AM
05truckguy
2004 - 2008 F150
Feb 20, 2011 09:59 PM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
danielharr79
1997 - 2003 F150
May 29, 2010 09:54 PM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
