LOUD KNOCKING UNDER DASH? (passenger side)
Old Feb 15, 2011 | 01:40 PM
05truckguy's Avatar
05truckguy
Exclamation LOUD KNOCKING UNDER DASH? (passenger side)
Any expert advice here would be great-
Truck-2005 F-150 XLT 5.4L
Problem-Currently when my truck reaches a speed of 45mph+ there is a methodical knocking sound that comes from the passenger side dash. This sound is on the interior and comes from the far right corner of the dashboard.(almost as if someone is tapping with there finger every other second). There is no correlation with anything else being turned on or off that affects this sound.(i.e. air) It simply happens once I reach a certain speed and is not an outside noise. When I slow back down under 45 mph the knocking subsides. Has anyone ever experienced this? Any suggestions?
<!-- / message -->
<!-- controls -->
Old Feb 15, 2011 | 03:57 PM
MCDavis's Avatar
MCDavis
When you get above 45, does the knock continue at the same interval when you're doing a higher speed, say 65, 75? Just trying to get more info out of you.
Does the knock sound hollow? Like a dead blow hammer on wood, or a ping like metal on metal?
Old Feb 16, 2011 | 12:08 AM
Shooter00's Avatar
Shooter00
Probably a Tommy Knocker. Just leave him some milk and cookies when you go inside for the night and it should subside! LOL
Old Feb 16, 2011 | 08:44 AM
05truckguy's Avatar
05truckguy
The intervals do not change as the speed increases, and the knock is a hollow wood sounding knock. It sounds like someone is tapping the plastic underneath the dash in the far right corner of the passenger side. ( I wish it was Tommy Knocker and some milk and cookies would get the job done.)
Old Feb 16, 2011 | 02:47 PM
planehunter's Avatar
planehunter
Was your truck made in Mexico??? LOL Just kidding. I had a similar problem on a car I had, found out that the windshield trim was lifting slightly at highway speeds. My guess is you have something similar but perhaps in your fenderwell or under the hood.
Old Feb 20, 2011 | 06:50 PM
Millzy's Avatar
Millzy
Try and adjust the temperture controls from hot to cold and see if the noise changes. I think you have a problem with your blend door motor.
Old Feb 20, 2011 | 07:03 PM
screwy's Avatar
screwy
This is just a wild shot in the dark, but on the far right of the cab is the recirculating air door. I wonder if it has somehow broken loose of its motor and is flapping about, maybe at speed the air pressure produced is enough to cause it to bang? That’s the only thing over there I can think of that might be remotely affected by speed, unless it is truly outside the cab. But I'd also expect that I'd be heavily influenced by the blower speed...
Old Feb 20, 2011 | 09:59 PM
Fox Fader's Avatar
Fox Fader
When I was installing a turbo on my Mazda3 years back, I ran the car w/o the bumper for a test drive and the inner fender did a similar knocking at a certain speed.
Krazee Matt
Oct 12, 2017 08:36 PM
bdlesch
2009 - 2014 F150
Nov 2, 2015 06:35 PM
thegreatgate
Modular V10 (6.8l)
Sep 28, 2015 08:31 AM
sitiakab
1997 - 2003 F150
May 29, 2012 05:50 AM
urbncby
Jan 13, 2009 07:11 PM
