Exhaust Break
I agree with the general consensus - the system we have works great. I've had it "save" me a couple times descending a slight grade into an unexpected stoplight or something similar. Not emergency stops, just shorter distances than I would have liked... the engine brake kicked in and slowed me down much quicker. I've also used it for long grades, to maintain speed without working the service brakes.
I think the *only* complaint I have is that it only works in tow/haul. I mean, that makes sense... but I like to turn off t/h for long stretches of flat ground - keeps the torque converter from locking up unnecessarily. I have to remember to turn it back on before descending a hill, if I want to use the engine brake. Not that big of a deal, but a couple times I have attempted to use it when not in t/h
Myself and some others have done a total of 4 different test meets where we drug 10-11,000 lbs up and down a steep hill with nearly every engine configuration ever put into a Super Duty. This included a 5.4L, 6.0L PSD, 6.4L PSD, 7.3L, 6.8L, 6.7L PSD as well as an unlucky Dodge that blew up going up the hill on our latest iteration.
Ever since 2003 and the introduction of the TorqShift 5R110 transmission we've had a tow/haul option at our disposal. This has always provided engine braking going down hills with trailers, and works pretty well. The 6.0L and 6.4L PSDs have no exhaust brake like our 6.7L trucks are claimed to have, yet downhill performance is VERY similar.
I don't find my new 6.7L truck to have any noticeable increase in braking force when going downhill than my 6.4L truck did. I'm not saying it's not there, just that it's not as significant as I think it should be.
Just my opinion, your mileage may vary.
I have not towed with a 6.4, but I can definitely feel the engine brake working on my 6.7L. I'm very satisfied with the way it works. This is why I wanted to make the point that it's not an exhaust brake. If you're expecting it to work like the butterfly version described above, you're going to be disappointed. It's not the same thing. But then, it was never claimed to be... some people just *assumed* that it would be.
I'll re-state my opinion on the matter - I think the system we have works well. It's not an exhaust brake, but it does function as designed. If you need more, you can always add an exhaust brake.
Jacobs is an engine brake and uses the valve timing to basically convert the engine into a big air compressor. Anything else that takes action downstream of the exhaust manifolds is an exhaust brake.
The 6.4 did not have any exhaust braking because of the configuration of the twin turbos. The 6.0 was not programmed to have this feature from the factory, but aftermarket tuning can utilize the VGT to create some pretty impressive exhaust braking. My 6.0 would literally make 15 lbs of boost under exhaust braking at 50+ mph in 3rd gear. The downside of both exhaust braking and engine braking is that they are most effective at higher rpm. You just aren't going to feel much out of them at less than 3000 rpm unless you have something like a 3 stage Jacobs on a large Cummins.
By the way, if you push it hard enough, the 6.7 will make boost when the imaginary exhaust brake is active.
It's a bit like Xerox making printers. They do... and if you told your average person that you just bought a Xerox, he would expect it to make copies. He would be disappointed that it only prints. It's still a Xerox... but it's not what people think a Xerox is. Not a perfect example, but it helps get my point across.
I believe most of what I saw in the 6.0 and 6.4L is simple compression braking provided by the engine at high RPMs. Either engine will downshift to 3,500 RPMs if possible coming down a hill to provide maximum braking force. My 6.7L does the same thing, and I believe the majority of braking force comes from the same compression braking we see on the 6.4L/6.0L trucks.
I'm sure the turbo exhaust braking has it's effect, but it's not as much of an improvement as I would have thought. Still, I belive it's perfectly adequate for any towing we'll ever see. It's just not as tolerant for making bad decisions coming down a hill as a more agressive one would be.
Locked converters allow the engine to use the torque more efficiently and keeps trans temp down by not having the TC slip.
