Sponsored by: Real Truck
Which trans fluid?
Old Feb 6, 2011 | 09:49 PM
Dr.feelgood's Avatar
Dr.feelgood
Which trans fluid?
i bought a used 2000 v10 and want to change the transmission filter and then add a mag hytec trans pan. The problem is i have no idea what fluid is in there right now. My manual says to use mercon which is not a problem but what if the previous owner or someone else put in mercon 5 or something else??? i dont want to flush the tranny . what happens if the 2 different fluids are mixed?
Old Feb 6, 2011 | 09:58 PM
DAVE67FD's Avatar
DAVE67FD
Don't worry about it. The Mercon V is what you want to use becuse Mercon is no longer produced.
https://www.ford-trucks.com/forums/1...?highlight=ATF
Old Feb 7, 2011 | 08:25 AM
Dr.feelgood
i can get mercon under the brand name "super tech" at my local wal-mart. So i dont necessarily have to use mercon v.
Old Feb 7, 2011 | 06:19 PM
projectSHO89's Avatar
projectSHO89
Then pick one and stick with it. The Mercon V is better, but if you want to use the old spec fluid, knock yourself out.
Old Feb 7, 2011 | 08:29 PM
Dr.feelgood
i will pick one. however no one has definitively stated that you can or can not mix the 2 different transmission fluids which is still the original question i posted.
Old Feb 7, 2011 | 08:45 PM
projectSHO89
It will not harm anything to mix the current Mercon V with some Mercon in your transmission.
You'd be better off flushing it and getting out the most Mercon as possible, but it won't hurt anything.
Old Feb 7, 2011 | 08:46 PM
twags6's Avatar
twags6
Originally you weren't supposed to mix them, but Ford states you can mix the new in with the old, but its only recommended in the power steering or transfer case, not in the trans. If you have it done at the dealer or shop, they'll put Mercon V in. Its whats recommended now by Ford. If you're worried about mixing the old with the new, do a trans flush by following these directions. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Its written by Mark K, a former ford auto trans engineer. Another pointer, don't go cheap with the trans fluid. Replacing the trans is much more expensive then spending a few dollars more on quality fluid.
kawika
49
Jun 23, 2021 11:47 PM
OnTheTrail
Sep 6, 2019 07:55 PM
01FordEx
Mar 28, 2016 10:59 AM
pete60hill
Jun 26, 2014 07:38 PM
blue84f250
Dec 29, 2013 10:54 PM
