Speedometer Problem
Old Feb 6, 2011 | 09:07 PM
HoustonGuy's Avatar
HoustonGuy
Speedometer Problem
Hey yall, i just bought a 1973 ford f100 4x4, over here we must have an inspection sticker and the truck has a problem. The speedometer doesn't work, when your going slow and bump the gas it will bump up a little. But regular driving it doesn't work. What should I do?
Old Feb 6, 2011 | 09:35 PM
83sd's Avatar
83sd
check the cable, could be broken, could just need luble.
Old Feb 6, 2011 | 09:56 PM
bucks77ford's Avatar
bucks77ford
^^^^ I agree, most cases it's just the cable. Take the cable off and inspect the inner cable. You can get replacements at almost all parts stores. Just remember if and when you replace it, lube the cable up really well.
Old Feb 8, 2011 | 10:34 AM
HoustonGuy's Avatar
HoustonGuy
Alright then, I'm not sure if the oil pressure gauge works, it stays at 10. The horn doesn't work as well. Does the horn have a fuse that goes to it in the fuse box, I'm pretty sure a couple fuses are bad.
88n94
Oct 14, 2014 09:56 PM
Hagerhorrible
Sep 1, 2013 11:45 PM
lstr81
Oct 10, 2012 12:31 PM
dfarland
Sep 23, 2010 03:06 PM
Walker1940
Jun 5, 2006 07:17 PM
