floor pan repair
Old Feb 6, 2011 | 06:45 PM
ford_0004's Avatar
ford_0004
floor pan repair
78 f-150 floor pan . Rear mounting holes for the seat are rusted out as well as the rear piece behind the seat . I've only came across whats sold in LMC and JBG . Do they make replacement sheet metal that far back or will I need to fab some new stuff ?
Old Feb 6, 2011 | 07:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The rear part of the floor pan will have to be fabbed. Only the front part is available aftermarket.
Old Feb 8, 2011 | 05:16 PM
ford_0004's Avatar
ford_0004
I was afraid of that .
Old Feb 9, 2011 | 08:38 AM
PA74F250's Avatar
PA74F250
Depending how bad the rear of the cab is a replacement cab might be the way to go.
Old Feb 9, 2011 | 08:58 AM
crazed87bronco's Avatar
crazed87bronco
i haven't seen any replacement floor pans for the rear section only the front pan area i got mine from LMC the rear section should be easy to do some flat sheet metal should do the trick cut out the old and overlap with a new piece and weld in place. depending if the rest of your cab is rusted or not a cab swap may be cheaper/easier to do like PA74F250 mentioned
Old Feb 9, 2011 | 10:50 AM
78 PEB's Avatar
78 PEB
PM sent............
