Sponsored by: Real Truck
Superduty2001
Old Feb 6, 2011 | 10:15 AM
superduty2001's Avatar
superduty2001
Superduty2001
My '01 F-250, CC, 7.3,4x4,Lariet, 4448,000 miles, Dome lights won't shut off until you exceed 15-20 mph after it is started. Where is the door switch located or is there one ?
Old Feb 6, 2011 | 10:30 AM
brd7666's Avatar
brd7666
Dang man, that's some serious miles you got there. Almost 4.5 million miles. I think you have a record there. Try spraying some WD40 in all the moving parts inside the door. A lot of times that will do the trick.
Old Feb 6, 2011 | 10:54 AM
superduty2001
correction
Had an extra 4 in the milage, should have been 448,000
Old Feb 6, 2011 | 11:50 AM
Chaosracing's Avatar
Chaosracing
I had that issue once before. Clean the door latch assembly with brake kleen, then spray with silicone, PB Blaster or WD40 ( I used PB Blaster) Also clean your door lock assemblies and lube them with graphite powder.
