Almost Bought the Farm
we fixed mine in the middle of a corn field in 30mph winds at negative temps. it was not fun to say the least bit. the box itself was fine, and yours probably is as well. we basically just changed out the sector shaft and a seal or two iirc. pretty simple and straight forward. all we had was a hammer, a pickle fork and a few wrenches. i'll go check in the garage and see if i have the broken parts still or not. think i do.
Daaaaaamn, your front end is wiiiiiiiiide! Looks like crap IMO but whatever floats your failboat.
Hydro assist will take some of the load off the sector shaft and help it last a little longer. Not sure if thats the answer you were looking for though.
Since you need a new box (well at minimum a new shaft and rebuild kit) you should give these guys a try for a rebuild and add hydro assist while they're at it if you arent confident in doing it yourself.
hydrosteering
rangers, no. go fly a kite pal.
did my own research today on the light duty trucks and they do share the same box from f-150 to 450. kind of sad really. i'll check on the big trucks eventually.
you should go cut your nuts off and start over with a new username because i was not impressed.
Second, I didn't mean to call you dumb, I think I misread your post and thought you were confused at the f-superduty f-450 thing, whatever, my bad.
RockAuto lists the same steering box for F-series, E-series and Rangers for many years. See here, click on "detailed applications"Maybe its just the 4wd Rangers, and 2wd could be different in some applications. I do know for a fact that the sector shaft is the same size in a 94 Ranger and an 88 F-250. I've done the sector shaft seal on both, and they were the same size. Either way, my comment was correct.
I apologize for saying you guys all beat on your trucks. I really didn't mean it that way. Just looking at the OP's pictures, that size tires, with the wrong offset on the wheels (single wheels on dually hubs) with a likely lift to make it fit, thats outside the original engineering specs on the truck. That was my point, offroaders sometimes modify their vehicles in ways that cause extra stress on components. Thats why solid axle swaps like dana 60's are so popular, the stock stuff gets pushed past its limits and breaks.
Ford has been using this design steering box since 1982 (according to rockauto, see above). If there were enough of these failing in that time due to design flaws, I'd think recalls would have happened. You're all right, if it breaks on the highway, you're ****ed, thats a big safety problem. There is a hell of a lot of them out there, I don't think it affects most people with how they use their truck.
tjc transport, if you've had 3 of these break, I imagine you're putting a lot of heavily loaded miles on your truck, and probably not on a smooth road. I dont know what to say, maybe I'm wrong, but these things shouldn't break under normal use.
To all of you, and especially Dan, I don't spend a lot of time in this forum because of the crappy attitudes you guys have. Personally I don't give a rats *** what you all think of me. I also don't know where you learned manners. I'll admit when I made a mistake, but it just seems all you guys what to do is get your panties in a bunch and spout all kinds of insults to inflate your ego's. In the future, I'll just stay to the other forums where people are kinder and want to help each other, not act like jackasses.
The farther ourt your tires stick the more leverage on the sector there is.
the 2 89's, 2 90's, 91, and 92 never broke sector shafts, but they were not worked like my 88 was.
