Gauge/instrument Cluster
Does anyone know how much different the instrument clusters from a 2000 F-150 and 2000 F-250 V-10 gasser are as far as mounting and clearance is concerned? Autometer sells an after market panel for a '99 - '03 F-150. I have done a little research to examine the differences, but I don't have an F-150 to physically compare my gauge cluster to. It would be interesting to see if the panel from Autometer would have the potential to be mounted in an earlier year superduty.
Kit from Auto meter Auto Meter 7010 - Auto Meter Lunar Series Analog Instrument Clusters - Overview - SummitRacing.com
Picture of stock f150 panel: P4366 - 3565
Picture of stock f250 panel: K1350 - 3402
If you look at both of them side by side, you will see that they are not shaped the same for one thing. Then there is the needle guages that are on opposite sides, so the wiring harness probably won't be the right length. I don't think it will work. Good luck.
lowtrkn2k
Nov 22, 2013 11:18 AM
TheKirbyMan
Mar 25, 2013 09:04 PM
thordehr
May 7, 2012 04:39 PM
KingBluey
May 17, 2011 11:16 PM
