Sponsored by: Real Truck
Batteries Draining/Won't start
Old Feb 4, 2011 | 08:46 PM
wesayso's Avatar
wesayso
I have a 7.3 2000 250. Have had several events over last two weeks with not starting. Over the past two weeks, have replaced alternator, starter, and starter solenoid as well as both batteries. Each time I have replaced something trucks starts fine for a few days and then.....when I attempt to start the truck acts as though batteries are nearly dead. Took to local Ford Dealer and they tested the new batteries both in the truck and out of the truck. Out of the truck, the batteries test good with full 850 cranking amps. Hooked up in the truck, the batteries show they are bad and only have about 400 cranking amps. Disconnect them from truck and they say they are fine. Something must be pulling all of the juice out of the electrical system and it must a big pull as the electrical system goes from behaving normally to acting almost completely dead in a flash. Please help! Where do I start here???
Old Feb 4, 2011 | 09:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
Are you sure the alternator you installed is good? Bad rebuilt alternators are more common than you might think.
Old Feb 4, 2011 | 09:15 PM
wesayso's Avatar
wesayso
the alternator was the first thing replaced two weeks ago. no issues starting for about a week after that, then had issues and replaced starter; again no issues starting for about a week, then replaced battery and solenoid. No issues starting for one day, and here I find myself. If it is the alternator, it is an intermittent issue? Thanks for your input. Any other ideas?
Old Feb 4, 2011 | 09:16 PM
F350-6's Avatar
F350-6
I'd start with checking voltage. Both key on and key off. Either use a multi meter or grab one of those volt meters that plugs into the cigarette lighter and displays battery voltage. I got mine from Walmart for pretty cheap.
If you can find a low voltage situation, start pulling one relay, then fuse at a tim. Replace it if there's no affect on voltage, but continue the test looking for a current draw. A better test would be to use a mulit-meter than can read current in milliamps to locate a minor draw.
You should also check your battery cables with a meter while cranking to make sure they are not corroded and causing the current drop. If you don't have a meter, jumper cables from a battery to an engine ground and to the starter relay should work for a test.
Old Feb 5, 2011 | 12:16 AM
carltonwebb's Avatar
carltonwebb
Check your glow plug and air intake heater relays to see if there is power on both big terminals with the key off. If either were melt internally and complete the circuit all the time, the batteries would not last at all.
On each relay, one big terminal should have power all the time. The other should not.
danielwd
1983 - 2012 Ranger & B-Series
Jul 11, 2014 08:20 AM
crazy96863
Jul 8, 2014 12:36 AM
Rich1953ard
Apr 28, 2013 10:34 AM
fishindave11
1978 - 1996 Big Bronco
18
Apr 17, 2012 04:38 PM
Rizzle
Electrical Systems/Wiring
Oct 20, 2005 07:53 PM
