headlights ?
Old Feb 4, 2011 | 10:30 AM
boaterbob's Avatar
boaterbob
headlights ?
Whats the procedure for replacing a headlight on a 97 explorer? Thanks
Old Feb 4, 2011 | 12:05 PM
shorod's Avatar
shorod
Just the bulb or the entire headlight assembly?
The owner's manual probably details the steps to replace just the bulb. If the '97 is like the 2000 there will be a little door above the headlight that provides access to the connector, retainer ring, and bulb.
-Rod
Old Feb 4, 2011 | 12:11 PM
97 Mountain Man's Avatar
97 Mountain Man
There are two access panels (one on each side) under the hood along the core support lift up the panel and you will see the plug and the plastic ring that retains the bulb. Just unplug the harness from the bulb, remove the ring and pull the bulb out. The left side is a little tight because of the battery but it's not hard at all.
Now my '97 Cougar is another story.
Old Feb 4, 2011 | 12:22 PM
boaterbob's Avatar
boaterbob
Thanks for the reply. Just took a good look and figured it out. Don't know why i was thinking 97 still had sealed beam heads.
InsanePyro
May 22, 2017 09:37 AM
mojavearcher
Feb 14, 2017 10:33 AM
1leg
Jan 3, 2017 02:04 PM
quincyj34
Nov 10, 2015 03:58 PM
cliffhanger228
Sep 2, 2015 04:59 AM
