Crazy Problems 2005 5.4
Old Feb 3, 2011 | 10:04 PM
darrell_1000's Avatar
darrell_1000
I have an 05 F-150 Lariat 5.4 and it has been going haywire today. While driving if I hit a hard bump the power will cut off (radio, a/c) and even sometimes the truck. Check engine light came on and I pulled codes P2160 & P0506. Also, when it completely cuts off and I start it back up it says "engine in failsafe mode". Does anybody have any idea what is going on? Thanks.
Old Feb 4, 2011 | 04:57 AM
celjel's Avatar
celjel
You have a loose connection somewhere. I would start by checking all the grounds first, and then move on to the connectors on the ECU. The reason I would start with grounds is that I had my transmission replaced in my 04 and the shop stripped the bolts on the starter. That's where the main ground is connected on one of the studs. I kept having the same thing, stalling, engine failsafe etc. After I replaced the starter( being loose it chewed it up)I replaced all the bolts & studs on it and of course with the ground secured properly again I have not had any problem again now in over 10k miles. Good luck.
Don Expedition
22
Dec 20, 2015 09:41 AM
jdhudall
Jan 14, 2015 07:24 AM
PorchFarms
1997 - 2003 F150
Nov 23, 2014 02:18 PM
Long bed ford
2004 - 2008 F150
Feb 19, 2014 09:19 PM
F0RD6uhl
Apr 13, 2011 10:01 PM
