Computer Chips & Tuners
sct problem 6.0 PS
Old Feb 3, 2011 | 07:55 PM
rpatton09's Avatar
rpatton09
sct problem 6.0 PS
I just bought a sct sf3 programmer and programmed my 05 f250 to well i was stopped at a red light and it just started pouring white smoke so i pulled over and returned it to stock now smoke is gone .i was on the street setting and wasnt in the throttle at all what could be causing this other than the programmer .
Old Feb 4, 2011 | 06:11 AM
shotgunz's Avatar
shotgunz
tex25025 (Ford Truck Enthusiasts Forums - View Profile: tex25025) will be along shortly to describe the pitfalls of canned tuners with 6.0 PSDs (plenty of posts in this forum - recommend you read them).
Call, e-mail, or PM Mike Butler (fordmdb) at 5Startuning.com.
Old Feb 4, 2011 | 09:16 PM
PwrHngry's Avatar
PwrHngry
How long after you programmed did you get the "smokey" experience? A couple miles? A couple days? It's pretty unusual to run into that type of situation all of a sudden. Usually, if it's going to run badly it'll do so right after programming.
Old Feb 20, 2011 | 05:28 AM
mikerichmon's Avatar
mikerichmon
I just traded my 2006 powerstroke for a 2011 f150 and had used both the superchips and sct calibrators for 81k miles. Never had any issues with either of them. I am going to put them on ebay
Old Feb 21, 2011 | 08:52 AM
tex25025's Avatar
tex25025
Well you have to remember that tuners can cause problems to be noticeable when you might not realize that you have them. The tuner could be changing timing just enough that you realize that there is a problem, but when you take it off, boom no noticeable sign of problem.
Smoke can be a number of things that is going on. Given that it seems to be related to if you have the tune uploaded, I would check for something like a leaking injector. Did you happen to smell unburned fuel? Did you happen to feel a miss?
Of course, you might have something else leaking into the exhaust causing it to smoke as well. The thing with tuners is that there are some increased temps and pressures and that might cause a leak to be more noticeable then if it was left in stock form.
Old Feb 28, 2011 | 08:44 AM
teppler's Avatar
teppler
Did you buy the tuner new or used and are you sure it is programmed for your stock strategy? If all is correct then I would try it again as it might be the tune did not go right the first time...try a different tune also and see what happens..
Old Feb 28, 2011 | 04:11 PM
teppler's Avatar
teppler
Duh... just noticed how old this post was!!
henken01
6.7L Power Stroke Diesel
Mar 29, 2017 07:41 AM
Crowbarr1
WTB - Parts & other
Mar 9, 2017 04:45 AM
js139
Jan 12, 2017 04:52 PM
xjcamaro89
2009 - 2014 F150
Jul 4, 2016 09:30 AM
ScreaminSporty214
May 12, 2015 01:24 PM
