6.9 Clutch HELP
Old Feb 3, 2011 | 12:50 PM
roy.prue's Avatar
roy.prue
6.9 Clutch HELP
Im taking my truck in on monday to have the clutch changed. Iv already bought the clutch and there was an option for a 11" or 12" disc. I got the 12" after i read somewhere that it will work with the 11" or 12", and be like sort of an upgrade... Am I correct?
Old Feb 3, 2011 | 03:44 PM
roy.prue's Avatar
roy.prue
No replys yet... This isnt good!! lol
Its also a 4spd tranny if that makes a difference.
Old Feb 3, 2011 | 04:29 PM
BlueOvalBud's Avatar
BlueOvalBud
According to the Napa website, both the 11" and 12" came up in a search for an 85 F350. Both are for a flat flywheel and have a 1-1/16" input shaft.
NAPA Online
And for what it's worth, the NP435, T18, and T19 4 speeds all share the same 1-1/16" input shaft measurement with 10 splines.
We have a T18 in the Jeep, it uses the same size disc my trucks use.
I've got spare clutch discs for my '65 F350 with NP435, '77/'79/'84 Jeep CJ-sumthing' (It's a CJ8 Scrambler mutt! LOL) with a close ratio T18, and three 85 F350 T19's, and they're all the same: 1-1/16" input shaft with 10 splines. We've also got some Jeep T150 3 speeds that my original IDI clutch disc fit onto last time I checked... It makes sense since the T150 is a version of the Ford 3.03 3-speed on the column.
When I make it out to the garage tonight I'll measure the clutch I've got on the spare 6.9 parts motor. I put a brand new Carquest clutch in my first IDI and then 1 month later the head gaskets let go... At least I can transfer them onto my current IDI when the time comes. And it works out good for you because now I can measure for ya!
Old Feb 3, 2011 | 04:33 PM
roy.prue's Avatar
roy.prue
NAPA Online
Thank you, your help is greatly apreciated. Iv done some more looking around and I think I was correct, it looks to be just bolt on and go. I cant wait to have a new cluch in the girl! New clutch monday, new plow on tuesday! Im also about to order New Injectors, gps, and return kit. Shes gona love me!
Old Feb 3, 2011 | 04:41 PM
BlueOvalBud
Please excuse the Hi-Jack...but what else are you planning for with the truck for future services/repairs/upgrades? Make sure you start a thread if you're not sure on something, there are definetly upgrades you can do when it comes time to replace certain parts.
Where are you getting the Return Line kit from?
Are you doing the IP the same time you do the Injectors? If you can afford the IP, it'll definetly be better to replace the IP and Injectors at the same time. Sometimes an old Injectino pump may not have the power to "pop" those new injectors open from what i understand. That's why I replaced my IP and Injectors at the same time.
Here's where I got mine: 6.9 Ford Diesel parts Fuel Injection Turbocharger
8 Brand new Injectors and a fresh pump, 2 years now and doesn't miss a beat! I get my return line kits from these guys also, awesome kit. Made by Dipaco Diesel. I called them directly and they told me the O-Rings are made from Viton.
And just making sure...you know to go with Motorcraft/Beru glow plugs!!
Can't remember the number, either ZD1 or ZD9 or something...check the 83-86 Glow Plug sticky at the top of the page!
Old Feb 3, 2011 | 05:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
nice.
if i ever get my dang timing meter part i need, i'll come over and time her for ya.
Old Feb 3, 2011 | 05:07 PM
snaponprofile's Avatar
snaponprofile
Originally Posted by FORDF250HDXLT
nice.
If you ever get that meter working, I might visit you there in maine
Old Feb 3, 2011 | 05:13 PM
BlueOvalBud
Has anyone actually put the 12" disc on an IDI?
I pulled the clutch set off my spare motor...I got some measurements.
The flywheel is 15-3/4" wide.
The clutch cover bolt holes are 12-1/2" apart ON CENTER.
The clutch cover bolts are 5/16" coarse thread wth 3/8" hex heads.
My clutch disc is 11".
So...how does a 12" clutch fit on the flywheel? Do ya need a certain flywheel or drill new holes or does the 12" clutch cover have a way of clearing the bolts?
With a 12" disc with a cover that has 12.5" distance between the bolts...that leaves 1/4" on each side.
Old Feb 3, 2011 | 05:16 PM
BlueOvalBud
Me too!!
We go up to Old Ocrhard Beach for a week vacation each year, and every other year we head up to Moosehead Lake!
Old Feb 3, 2011 | 06:30 PM
BlueOvalBud
I've been looking for my camera to take some pictures and post up...but it seems to have grown legs and walked away.
When I find it, I'll take some pictures and post up!
Old Feb 3, 2011 | 07:19 PM
BlueOvalBud
All right...
First off, got a correction to make. I think the clutch cover/pressure plate bolt holes are more like 13" apart. I wasn't measuring straight across the flywheel when i got the 12.5".
11" pressure plate
11" pressure plate, overall width is 13.5".
11" disc
Flywheel, overall width 15.75"
Pressure plate bolt holes, about 13"
I'm really curous if someone has used a 12" clutch set, and how they liked it.
Old Feb 3, 2011 | 09:22 PM
farmert's Avatar
farmert
I'm thinking you would have to go with a matching 12" pressure plate for a 12" clutch. I always go with a new pressure plate with the clutch, although I have never knowingly used a 12' in place of an 11". When converting to the single mass flywheel a 12 inch is used.
Old Feb 3, 2011 | 09:29 PM
BlueOvalBud
Oh yeah, absolutely install a new pressure plate and clutch disc. I worded that wrong in my post, fixed now. 11" pressure plate with an 11" disc. 12" pressure plate with a 12" disc. No mix and matching, you want the surfaces to be as tight fitting as possible.
I'm just curious on how a 12" pressure plate fits on the flywheel.
Old Feb 3, 2011 | 09:33 PM
roy.prue's Avatar
roy.prue
I guess we will find out on Monday. lol
Old Feb 3, 2011 | 09:38 PM
BlueOvalBud
Do you have links to any places you were reading about the 12" clutch? If they sell it, then I'm sure it fits... I'm just curious is all, since I know I'll be doing my clutch within a year or two. I might just use this spare clutch on something else and toss a 12" in the IDI.
