Sponsored by: Auxito
engine replacement
Old Feb 2, 2011 | 10:21 AM
jdpenny's Avatar
jdpenny
engine replacement
What years of the ford 4.2 liter engine will fit in my 2003 F150
Thanks
Old Feb 2, 2011 | 02:06 PM
bluntman999's Avatar
bluntman999
1999 to 2003 will fit your truck i think maybe even 98 will fit, but id double check on that. I know for sure that 99-03 is a direct bolt in.
Old Feb 2, 2011 | 10:47 PM
Area6567995's Avatar
Area6567995
yep 99-03 shoudl work
Old Feb 3, 2011 | 10:38 AM
jdpenny's Avatar
jdpenny
That's what I was hoping for - I see salvage yards selling engines that state only good for 2001 -2004 - Also in the chilton manual it shows a different intake manifold for pre 2001 4.2 liter engines. (Don't know if that makes a difference or not)
Old Feb 3, 2011 | 01:04 PM
bluntman999
idk
ya then id measure ur intake, depth an width if it will fit in there you go!! If not guess u,ll have to find the 01 an up, but everything i read says 99-03 is a direct bolt in.
Old Feb 3, 2011 | 01:06 PM
jdpenny's Avatar
jdpenny
Thanks for your help
Old Feb 25, 2011 | 02:24 PM
brokenleg's Avatar
brokenleg
I put a 2000 V6 in to a 1997 F150. had to change the lower and upper intakes.and on the 1997 there is a sensor that screws in the block near the starter, the 2000 engine didnt use a sensor there. I put the sensor in there. the front of the engine is the same, timing cover, water pump, all that is the same. both engines were automatics, so no difference and the exhaust manifolds and O2 sensors are the same. and swap over the 1997 wiring harness over. otherwise the engine was the same.
jowilker
Nov 10, 2012 10:43 AM
bigfordman70
Jun 10, 2012 07:55 PM
Pastmaster
13
Jun 24, 2011 09:20 AM
bgodkin
Ford vs The Competition
Dec 26, 2008 10:23 PM
fordmaniac21
Jan 2, 2003 07:10 PM
