e-brake
Old Feb 1, 2011 | 09:40 PM
aking225's Avatar
aking225
e-brake
so, i hae an 87 f250 with a siezed emergency brake, the pedal wont go down if you press on it and its not stuck down. any ideas on hwat i should be looking for or how to fix it?
Old Feb 1, 2011 | 09:54 PM
IowanStraight6's Avatar
IowanStraight6
cut em and forget them or tear apart the drum and fix em the right way good thing to note about e-brakes either use them regulary or forget em totaly cause when they arnt used and you try engaging them they will sieze and never move again
Old Feb 1, 2011 | 09:55 PM
GLR's Avatar
GLR
Disconnect the front cable from the rears. Junction is on driver's side near front of bed. Now try the pedal-works=rears frozen no work=front cable frozen. I don't really like to pull on the rear cables too much as it is a pain trying to get the drums off with the emerg brake on.
Old Feb 1, 2011 | 10:01 PM
GLR's Avatar
GLR
225 I see your in MA. Odds are both front and rear cables are seized. Not worth trying to free them up. I replaced the rears on my 87 F250 this past fall. Maybe $36-40 for both rear cables.
Old Feb 1, 2011 | 11:11 PM
CWPottenger's Avatar
CWPottenger
Easiest way is to replace entire cable assemblies so you it's all good... going without is not the best... I for one have needed a E-brake on one than one vehicle who had main brake failures...
Old Feb 6, 2011 | 07:14 PM
aking225's Avatar
aking225
Thanks guys I've been away for awhile but I'm going to try some stuff tomorow but I think I'm just going to end up replacing it, how easy do you guys think it would be to do myself
Old Feb 6, 2011 | 09:28 PM
GLR's Avatar
GLR
I would isolate the cables first to see which ones might be seized. When I first got my 87 the emerg brake pedal would not move. Disconnected at the junction and the pedal moved freely.
Old Feb 8, 2011 | 08:02 PM
aking225's Avatar
aking225
so, i couldnt free anything and i got frustrated and hacksawed the bolt going from the equalizer to the junctoion, and the pedal moves very freeley, were can i buy both and where do i go from here
Old Feb 8, 2011 | 08:19 PM
GLR's Avatar
GLR
I got both my cables from NAPA. Interesting: one side made in USA, one in China. Don't know if they have a listing for other parts. Hit up our sponsors or any other sites. To get an idea of prices and availability.
Old Feb 8, 2011 | 08:35 PM
aking225's Avatar
aking225
i dont need the cabels though, i need all of th other hardware though
Old Feb 8, 2011 | 08:36 PM
aking225's Avatar
aking225
when i went to napa today, they said they didnt carry anything like it
Old Feb 8, 2011 | 08:58 PM
GLR's Avatar
GLR
Junkyard, dealer, or might have to make the rod (if that's what you cut).
Old Feb 8, 2011 | 09:18 PM
aking225's Avatar
aking225
alright, ill check on that tomorow, ill keep you posted
Old Feb 8, 2011 | 09:35 PM
CWPottenger
look here: LMC Truck Parts - Page 139
