I didn't get a chance to drive mine either my uncle parked it in the back yard some 30 years ago and thats where it sat till I rescued it just under two months ago. Here what it looked like than.
But I hate to say I actually like your old aluminum slots better ( except for the fake knock off centers on them ) . I don't care for the newer style rims on the old trucks. But I'm sure a lot of guys hate a lot of things I'm doing to my pile of parts too!
I wanted something that i didn't have to clean every week. My mustang is a bitcccchhhh to keep clean. My black Lab like to mark his tires every time i get home. lol
Hmm....mine was towed home. After I replaced the ICM, it ran for a while. Then I blew the 283. It sat that way for a few months, pulled it out, sat for another 5 years. Last year I built the 289, found a 4-speed and dropped em in. We wired it up, and I have been driving/fixing stuff every since. Most recently I replaced the whole front end from a donor truck. Next up is a drop axle and lowering the rear.
since i got the truck...Lets see?? i`ll put it this way, there`s not one panel on the truck that hasen`t been modified
89 crown vic front end
cv rear end 4 linked
air bags all around
boxed frame
homeade box
top chopped
drip rails removed
one piece door windows
bear claw latches
dash shaved
t bird floor shifter
crown vic steering column
hood sectioned
custom radiator support
custom front fenderwells (in the works)
custom hood lift (in the works)
5.0l with aod
firewall shaved
-things still to do:
chevy front bumper
guage cluster possible installation of `59 impalla cluster?
integrate front fenders into custom running boards with homeade exhaust tip
center console i built has to be redone to integrate t bird shifter
bunch of fiberglass finishing panels
Got my panel last March.Since I have installed a Volare frontend, 9" rear, motor mounts, transmission crossmember and rebuilt the rear springs. Hope to be drivable by summer.
Josh, it's Palisade green and it's actually the original color. When I found the color behind the gas tank, I thought it was sea mist green because the color charts only showed that as the light green, but it turns out that for 1950 it was replaced by Palisade green. The only company that I found that has the formula is Sherwin Williams and their Martin Senour brand (NAPA)
Joe, Do you know when and where "Edith" was built. I think that my 1950 F2 is the same color but we can't read the color code stamped into the firewall. What was the color code on your truck?
I just came across the picture of your truck in yellow. I like it! What color is that? Also how did the paint hold up on the running boards over the exhaust. Would you share some pictures of it from below?
I have a couple problems to deal with on my 1950 F2 before I put paint on it (see attached picture). Results of many modifications from many POs.
One of them shortened the wheelbase from 122" to 112" and added cab-chassis short running boards. My original thought was to lengthen the wheelbase to 114" and add F1 full running boards but after looking at yours there may be other options.
if we all are detailed enough.... this could be the longest (in inches) thread on FTE site
"It all began in a little 5000 watt radio station in Fresno. No wait that was Ted Baxter...
1995... the saga begins
Trailered home
wife walks out to driveway... shakes her head and returns to house
I should have taken that as a sign.
Took it apart down to the frame
Removed all remaining glass
Sandblasted frame
Soda blasted cab
Sent the front clip to Norway
Scrapped the bed,tailgate,bumpers
Installed ladder bar hung 9”lincoln rear end
Installed volare front end
Fabbed installed engine mounts
Installed 460 /c6 combo
Fabbed transmission cross member
Removed volare front clip
Endured months of volare crap from FTE buddies
Installed mustang ii ifs
Re fabbed engine mounts
Re fabbed transmission cross member
Installed larger disc brakes on MII
Crap from FTE ‘buddies” continues but in MII mode now
Replumbed brake and fuel lines
Installed Mustang fuel tank behind rear end
Replaced all 4 cab corners
Replaced door bottoms in/out
Replaced floor boards and toe board
Removed door handles/locks
Removed cowl vent and right heater vent
Installed bear claw latches and solenoids
Installed caddy seats
Removed caddy seats
Installed Chevy truck seat
Installed Chrysler column
Removed Chrysler column
Installed Ididit column
Installed modified Chrysler p.b. booster
Installed modified Chrysler hanging pedals
Installed Ford Truck parking brake pedal
Installed e-brake cables from Control cable
Installed 460 / C-6 combo again
Installed new fabbed driveshaft
Installed fiberglass front clip (at least 7 times)
Re-design on front cross member for radiator
Installed custom alum radiator/fan/evap
Removed all of the above “installed” parts for frame paint
Painted frame/suspension
Reassembled it all again
Blended in drip rail on cab
Frenched in antenna in cab
Installed 3rd brake light in rear wall
Fitted up running boards and rear fenders
Attached lower fender cuts to cab
Took all that off
Found out that radiator might not fit
Had engine built
Built engine stand
Built engine run in stand
Installed bed
Installed roll pan
Installed wheel tubs
Tried to make all this crap fit together
Installed tailgate
Starting year 17…continuing with body work on cab
Hood, bed,etc..
Waiting for engine run in and return to see
If the dang radiator will fit
And the saga continues I'm sure I forgot something !
Drove mine everyday for the first three years I owned it. Driven on and off since then but, once I moved to OK I parked it because the bump steer was more pronounced on the bad roads here.
Now I am redoing the entire suspension. Did the rear first then had a house fire and some other things happen and so now I am back to working on it. I hope to have it up and running this summer.
Well, I didn't make the summer deadline last year. Maybe this year...
All that remains is:
filling the radiator, transmission and gas tank.
installing exhaust, bed floor, battery and 2 cables, air ride control system. installing and re-wiring taillights
install seat and some more sound deadening stuff and carpet, door panels, kick panels and headliner.
Then I can start saving to do the body work and paint.
Disc brakes, T5 trans, Water pumps, Fuel pump, and Mirrors
Next is power steering and then radio, carpet and headliner. Its road worthy and I drive it alot in the condition its in.
