a real econoline steering fix!
#421
After several weeks of running the skyjacker stabilizer I have put the ford one back on. The skyjacker does not control the steering from movement as much as the ford one, it is bigger and I thought it would be stronger but its not and so at all speeds the skyjacker lets the steering move around a lot more and bumps move it around too. Thought I would let you folks know my experience with it. Andrew.
#424
anyone have experience with these ones:
https://www.ford-trucks.com/forums/1...ng-fix-28.html
More Information for RANCHO RS97481
More Information for MOOG SSD50
http://www.rockauto.com/en/moreinfo....121847&jsn=491
http://www.rockauto.com/en/moreinfo....121847&jsn=495
I can't get skyjacker kit, so these are only choices for me.
which would you choose ?
#425
#426
Yes. It appears Ford ships the E Series with a fixed bushing setting the caster at about +3 degrees which is OK for city driving. For highway handling you want to have +5 or more caster.
Too little caster manifests itself as "loose steering" and "wandering" at highway speeds.
Do you know if that applies to a 2012 E250 cargo van..??
I have similar wandering issues.. after the right tie rod was replaced and a camber bushing kit was installed. It now, also pulls right under braking..- a caliper issue I presume..! The Co's service provider hasn't gotten it right yet...!! UGH..
Thanks for any feedback...
#427
Hi,
New member with a 2003 E150. Last year for the 4.2 V6. Love my van. I put 136,000 miles on it and I too need to "tighten" up the steering. I did this stabilizer upgrade from reading this post and it has helped a lot. My question is, will this "adding 5+ degrees caster" work for the E150 also? I read about this for the E350/450 but nothing was mentioned about the E150.
Thanks for all the great info!
#428
I just installed the damper.
The steering feels slightly more heavy. The real difference is on rough roads and above 50mph. The front end no longer requires constant corrections and any required corrections are much smaller and infrequent.
Straight line driving is much improved. For the first time ever driving this van I never got tired after a trip.
The frame is thick enough to mount the bracket. The bolts are indeed self tapping.
#429
Hi,
#431
Hi,
.They, Ford had to put in a new steering box..and now, steering feels 'loose' to me...- Can the box be tightened up a bit..to take up some 'slack'..??
Maybe its tire pressure...??!
Who knows...
#432
#433
#434
.. I've thought about that too, re: adding the 5+ caster...but this is my Co., van..serviced by Ford, who goes by spec.... - They dont 'tinker' like whats been suggested here...( too bad..!!)...
Who knows...
Who knows...
Adjusting the steering box won't do much to affect the steering "feel". There is a procedure that's rather involved and requires use of a torque wrench calibrated in inch-pounds, the dial reading type preferred.
This is a great question---I'd like to know if only for the information. My guess is yes the holes are there as I hear the frames of the two "eras" pre-and post- 1992 are very, very similar.
#435
This is true but in all my travels and conversations about these chassis I've yet to find even one alignment person who believes this change is beneficial, even more rare one who'll actually do it to a customer's specs rather than the strict +3 degrees that seems to have become an industry standard of sorts (for the E-Series).
All I can say is that 5 degrees made a huge difference in the way my van keeps a straight line.. When I replaced my damper because it had leaked all its oil I couldn't tell any difference On or Off, other than it was harder to turn the wheel with a new damper back on.
