a real econoline steering fix!
  #421
Old 01-23-2017, 04:37 PM
andrewzx92000's Avatar
andrewzx92000
andrewzx92000 is offline
After several weeks of running the skyjacker stabilizer I have put the ford one back on. The skyjacker does not control the steering from movement as much as the ford one, it is bigger and I thought it would be stronger but its not and so at all speeds the skyjacker lets the steering move around a lot more and bumps move it around too. Thought I would let you folks know my experience with it. Andrew.
  #422
Old 01-23-2017, 04:41 PM
andrewzx92000
My initial impressions were that the skyjacker was stronger and it might have loosened up a bit over the time, but its definitely not stronger now.
  #423
Old 01-23-2017, 07:11 PM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
Thanks for the heads-up.
  #424
Old 03-29-2017, 10:37 AM
monstrs's Avatar
monstrs
monstrs is offline
  #425
Old 03-29-2017, 12:02 PM
WarrensE350's Avatar
WarrensE350
WarrensE350 is offline
I am finally getting around to installing the parts I got from JWA back in 2014. I can't believe I waited this long either. Anyway, with the other stuff I'm fixing up preparing for the 1,000 mile one way trip coming up, this is probably the one I'm most excited about.
  #426
Old 04-09-2017, 01:55 PM
TJ-Ranger's Avatar
TJ-Ranger
TJ-Ranger is offline
Originally Posted by Harvard
Yes. It appears Ford ships the E Series with a fixed bushing setting the caster at about +3 degrees which is OK for city driving. For highway handling you want to have +5 or more caster.
Too little caster manifests itself as "loose steering" and "wandering" at highway speeds.
Do you know if that applies to a 2012 E250 cargo van..??
I have similar wandering issues.. after the right tie rod was replaced and a camber bushing kit was installed. It now, also pulls right under braking..- a caliper issue I presume..! The Co's service provider hasn't gotten it right yet...!! UGH..
Thanks for any feedback...
  #427
Old 05-25-2017, 07:36 AM
70CJ's Avatar
70CJ
70CJ is offline
Originally Posted by JWA
Adding 5+ degrees caster is a known improvement in the E-Series---
Hi,
New member with a 2003 E150. Last year for the 4.2 V6. Love my van. I put 136,000 miles on it and I too need to "tighten" up the steering. I did this stabilizer upgrade from reading this post and it has helped a lot. My question is, will this "adding 5+ degrees caster" work for the E150 also? I read about this for the E350/450 but nothing was mentioned about the E150.
Thanks for all the great info!
  #428
Old 07-10-2017, 07:19 PM
98Econoline150's Avatar
98Econoline150
98Econoline150 is offline
I just installed the damper.
The steering feels slightly more heavy. The real difference is on rough roads and above 50mph. The front end no longer requires constant corrections and any required corrections are much smaller and infrequent.
Straight line driving is much improved. For the first time ever driving this van I never got tired after a trip.
​​​​The frame is thick enough to mount the bracket. The bolts are indeed self tapping.
  #429
Old 07-10-2017, 08:21 PM
JWA's Avatar
JWA
JWA is offline
Received 1,418 Likes on 1,118 Posts
Pulling to one side during braking is almost always a caliper issue---could be as simple as lubricating or replacing the caliper slide pins. +5 caster should work on all E-Series so a '12 E250's steering would be included in this suggestion
Originally Posted by 70CJ
Hi,
This fix should work on the entire E-Series from the E150 to the E350.
  #430
Old 07-13-2017, 03:49 PM
tractorfix's Avatar
tractorfix
tractorfix is offline
I haven't read every post over 29 pages but was able to install this setup on my 1986 E350. Works awesome
  #431
Old 07-13-2017, 09:52 PM
TJ-Ranger's Avatar
TJ-Ranger
Hi,
.. I've thought about that too, re: adding the 5+ caster...but this is my Co., van..serviced by Ford, who goes by spec.... - They dont 'tinker' like whats been suggested here...( too bad..!!)...
.They, Ford had to put in a new steering box..and now, steering feels 'loose' to me...- Can the box be tightened up a bit..to take up some 'slack'..??
Maybe its tire pressure...??!
Who knows...
  #432
Old 07-13-2017, 10:57 PM
Harvard's Avatar
Harvard
Harvard is offline
But the Ford Specification for Caster is from +1.5 to +7.5, so +5 is well within the specified range.
  #433
Old 07-14-2017, 03:55 AM
kaz442's Avatar
kaz442
kaz442 is offline
Were the holes already there on the frame like the '92-'15 chassis?
  #434
Old 07-14-2017, 04:43 AM
JWA's Avatar
JWA
JWA is offline
This is true but in all my travels and conversations about these chassis I've yet to find even one alignment person who believes this change is beneficial, even more rare one who'll actually do it to a customer's specs rather than the strict +3 degrees that seems to have become an industry standard of sorts (for the E-Series).
Who knows...
You certainly can't spec a company vehicle differently from standards so that's out of the question to be sure. If tire pressure is set to the factory specs according to your chassis you should maintain that. Here's the FTE thread about steering gear pre-load lash adjustment done the correct way: https://www.ford-trucks.com/forums/1...one-right.html Keep in mind mucking about with this could damage the steering box or at minimum cause early failure---proceed carefully!
Adjusting the steering box won't do much to affect the steering "feel". There is a procedure that's rather involved and requires use of a torque wrench calibrated in inch-pounds, the dial reading type preferred.
This is a great question---I'd like to know if only for the information. My guess is yes the holes are there as I hear the frames of the two "eras" pre-and post- 1992 are very, very similar.
  #435
Old 07-14-2017, 09:50 AM
rebar13's Avatar
rebar13
rebar13 is offline
I'm guessing this is due to the time and parts it takes.. When the alignment machine says its within ford specs, why mess with it? Right?
All I can say is that 5 degrees made a huge difference in the way my van keeps a straight line.. When I replaced my damper because it had leaked all its oil I couldn't tell any difference On or Off, other than it was harder to turn the wheel with a new damper back on.
Quick Reply: a real econoline steering fix!
