Manual conversion
Old Feb 1, 2011 | 09:39 AM
PowerStroker94's Avatar
PowerStroker94
Manual conversion
Hey guys,
I am looking into swapping a manual transmission into my truck in fear that my E40D will go any day now. I know in 95 they only had the 5 speed and ford started putting the 6 speed in there trucks in 99. Can I put the 6 speed in my truck, or should I just go with the 5 speed? And which ever one I end up using, how hard is it going to be to do the swap. Thanks
p.s. What are the model numbers from the 5 and 6 speed manual?
Old Feb 1, 2011 | 02:04 PM
JamesHajek's Avatar
JamesHajek
The 6speed is a larger transmission. You will need to make room for it if you do decide to go that route. Do a search on this site, Many of the members have done auto to manual swaps and there are a couple write ups. I will search for the 6speed write up...
http://www.powerstrokenation.com/for...t=45486&page=3
http://nwforddiesels.com/cgi-bin/yab...num=1291142102
Old Feb 2, 2011 | 06:04 PM
redman84's Avatar
redman84
You are going to be looking for a ZF S5 or ZF S6. The 5 is a direct bolt in and go(obviously using the other parts that make it a manual). the 6 speed requires some modification of your floorpan and driveshafts to account for the larger sizing. Neither one are too terribly hard especially the 5 but the 6 requires some skills and know how to pull off.
Old Feb 2, 2011 | 06:35 PM
PowerStroker94
ZF S5 crank HP
Does anybody know how much crank HP the ZF S5 can handle?
Old Feb 2, 2011 | 06:43 PM
redman84's Avatar
redman84
Not sure what it is rated for. Torque is either 420 ft lbs or 470 ft lbs depending on which year. BUT they can handle loads more with a good clutch. There are guys doing crazy stuff and blowing the specs out of the water with good clutches.
