1991 f-150 transfer case problems
Old Jan 31, 2011 | 08:58 PM
dgoertel's Avatar
dgoertel
i have a 1991 fi150 xlt lariat 5 speed 4x4 with a 5.0 its got 95000. . when i put my truck in 4 wheel drive (hubs in as well) when i mash on the gas it makes a sqeeking sound an the faster i go the faster an more hi pitch it gets. but if i keep my foot on the pedal goin a constant speed it quites down then when i left off the gas it gets loud again. it sounds like my driveline is scraping on something but there is no marks it has a little wabble in it but it looks ok. a mechanic said it was my transfer case but i dunno if it is an i dont wanta replace it an still have that problem o an its got new warn manual hubs an wheel bearings. 15,000 on both
Old Feb 1, 2011 | 06:48 AM
bigern6697's Avatar
bigern6697
I am not gonna say its not the transfer case but I am thinking more along the lines of a U-joint on the front drive shaft. When you first start going it is under a lot of load until you get to a constant speed and maybe there is less load. Just my thoughts on it, good luck.
Old Feb 1, 2011 | 06:53 AM
CWPottenger's Avatar
CWPottenger
hub bearings possible too .
Old Feb 2, 2011 | 09:56 PM
dgoertel's Avatar
dgoertel
hub bearins are fine you joints are as well not loose or warn down i did torque then to be safe. i do have a some oil coming off of my transfer case im not sure on the exact location ill clean it off an put some dy in an then find it. But still makes that this bad sound as if a drill bit would make when you drill through steel an start squeaking
Old Feb 2, 2011 | 09:57 PM
dgoertel's Avatar
dgoertel
Sorry not sure on the exact location the oil is coming from appears to be on the top though
Josh726
1997 - 2003 F150
13
Dec 4, 2015 08:56 PM
mx21
Sep 25, 2014 08:01 PM
Enduroman
Dec 6, 2013 02:53 PM
Alpha Lima Romeo
20
Dec 6, 2013 08:57 AM
SMRT
Nov 29, 2013 01:37 PM
