i have a 1996 with obd1 as well, i didn't realize this until after i had already got a jet performance programmer that has an obd2 connector questions is can i buy a obd1 to obd2 adapter and still use the programmer? and where is the obd1 port?? i can't find it anywhere, only thing i see is a ECC test connector
There is a great DIY tune up artical that has been brought back to life quite a few times since the short time I have participated.
Mileage = efficiancy . If you have ever participated in a pinewood derby the same rules apply. Rolling resistance, tire pressures, drive line vibration, front end alignment, brake drag etc.
