injectors
Old Jan 3, 2003 | 12:01 PM
moonshot314's Avatar
moonshot314
injectors
What do i do to check or clean injectors? What things should be done to them and how do you do them to keep them at optimal performance?
Old Jan 3, 2003 | 10:35 PM
steve83's Avatar
steve83
injectors
[updated:LAST EDITED ON 03-Jan-03 AT 11:35 PM (EST)]Checking isn't really possible with them installed - you need a special test rig, but it's kinda moot. If you think it's bad enough to pull one, just put a new one back in.
I just run some decent FI cleaner after every other oil change (~5000mi), and I vary which brand & type I use. Sometimes the $3/bottle stuff and sometimes the $10. Even though mine were so bad when I bought the engine that I had to short them for a minute or so to get them hot enough to open, they've run perfectly for the past 4 years.
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=13217
Old Jan 4, 2003 | 10:17 PM
MW95F250's Avatar
MW95F250
injectors
Carb cleaner should work, too. It'll clean out just about all gas engine systems.
Old Jan 4, 2003 | 10:24 PM
MW95F250's Avatar
MW95F250
injectors
Old Jan 7, 2003 | 12:38 AM
dvldog458's Avatar
dvldog458
injectors
Chevron fuel injector (with Techtron)cleaner is the best.
