06 Expy giving me trouble
Old Jan 31, 2011 | 02:00 PM
Davez99Expy's Avatar
Davez99Expy
I've had my 06 EB Expy for a year now and it's been great so far. Yesterday, the CEL light came on and these are the codes:
P1509
P0113
P0118
P1298
I have a feeling that the p1298 is the root cause of the other codes. What I'm not sure of is if it's an injector or coil over pack. Anyone have any ideas?
Old Jan 31, 2011 | 07:02 PM
Davez99Expy
Update - I took it to a mechanic because these codes just didn't make sense. He scanned it and came up with P0302. That seems more like it. Misfire on Cyl #2. I'm going to replace the spark plug and coil pack and see if that fixes it.
Old Feb 3, 2011 | 10:34 PM
Pro DIY's Avatar
Pro DIY
That should fix it I think. I usually keep an extra spark plug and coil around so that I can fix it as soon as it happens. If you wait to long it will screw up your cat.
Old Feb 4, 2011 | 09:05 PM
ronjeremy6's Avatar
ronjeremy6
my 05 did this and it ended up being a stuck fuel injection. our trucks have an extended warranty on the injectors. like you, i replaced the coil and plug on the cylinder with misfire and the problem returned. there is a TSB on the issue.
