Leaking Oil???
Old Jan 31, 2011 | 10:54 AM
jasontrucks76's Avatar
jasontrucks76
Leaking Oil???
Hey guys... I have a problem that is driving me nuts and needs some advise.
I have had a very slow drip from my oil plug on the bottom of the oil pan for a while now and cannot seem to get it to stop. I changed the oli last week and inspected the threads on both the oil pan and the plug. The plug looked a little suspect so I replaced it with a brand new on and it tightened down real good. I filled with oil... 5-40 Motorcraft and went for a drive. Parked her in the garage and after a few days of sitting I had a pretty big spot on the floor. 1/2 quart maybe?
Anyway... this seems like it should be such a simple task but again the plug and the pan threads all seem to be in good shape. I know for sure it is coming out at the plug because I wiped it all down real good and can tell it is not running down the pan fron say a pan gasket or rear main.
Anyone else have this problem? It seemed to present itself once I switched to 5-40 from 15-40. I realy like the 5-40 here in western SD for cold weather starts and would like to continue to use it.
Thanks,
JT
Old Jan 31, 2011 | 11:04 AM
FishOnOne's Avatar
FishOnOne
Replace your drain plug washer with a new one. Your local Ford shop can supply you one. I've replaced mine several times due to leaks.
Old Jan 31, 2011 | 11:14 AM
jasontrucks76
I did that with the new plug last week... Thanks tho!
Old Jan 31, 2011 | 12:00 PM
wulfman's Avatar
wulfman
Mine does the same thing but does not drip on ground just seems a little wet around plug. Been that way for years.
