<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> Hey guys any of u all know the difference in an 02-05 6.8 and a 00-01. Can u use the long block of the 05 in an 00?
Depends on what application it came out of.
'05 F250/F350's used the 3V cylinder heads, and the '05 Excursions and E-Series used the 2V heads.
JL
Its going in a 2000 x. Out of an 05. Sorry for the confusion
Is the engine from an Excursion or Econoline?If so, then it's a 2V and will work.
If it's from an F250/F350/F450, then it's a 3V and will not directly swap in.
JL
JL
As far as physically bolting in, yes-the 2V 6.8L's are all the same externally as far as mounts,etc go. You will have to mix and match the accessory drive, intake manifold and oil pan to match your vehicle, and you'll need to be cautious of the CNG versions of the engines-they have oddball compression and weird camshaft specs.
JL
