aod transmission
Old Mar 9, 2003 | 09:17 PM
albesure's Avatar
albesure
Question aod transmission
Hi, i need some help! i've got an 86 e150 with automatic overdrive that wont shift out of low gear. so i figured ok change the filter and the fluid. in the pan i found little chunks and grindings what appear to be needle bearings (about 2 tablespoons worth) i changed everything anyway and after warming up it actually shifted for about a week of running back and forth to work. then it started the same thing again.ok so maybe its shot.
i found what looks to be the same thing in the u-pull-it junk yard. is this a good idea and how do i check it out to be sure its the same. the pan is clean but its an 87 e150 will it work.
your feedback and advice is greatly appreciated,
thankyou, albesure
