Excursion seats into a superduty crew cab??
Old Jan 30, 2011 | 05:52 PM
4604x4's Avatar
4604x4
I looking to update my 99 crew cab that has 40/20/40 front seats tan leather interior.
Would the Excursion front buckets/console & the center seats bolt directly into a 99 superduty crew cab?
How about the center row of seats. Will they bolt in to a superduty w/ the crew cab
What years of the superduty are direct bolt in's?
Thanks
Old Jan 30, 2011 | 09:52 PM
wallz's Avatar
wallz
The front seats will fit. The other part of that question is hard to understand.
You can use the 40/console/40 seats, or the 40/20/40 or the solid bench. The seats are easier to find from the f series trucks as there are more on the road, or wrecked. Like the f series the buckets with console have the arm rests that will be in the way if you remove the console and add the 20 jump seat. The floor plan bolt areas are the same so the middle X seat should fit the truck and vise versa. You may just have slight colour diff from 99-00 to 01 and up.
Old Jan 30, 2011 | 10:11 PM
4604x4's Avatar
4604x4
wallz, thanks for the reply.
I have found a rear seat out of a 08 350, but looks to be a much lighter tan than the 99 is.
Do you know if the door panels interchange from the 08 to a 99?
Thanks again
Old Jan 31, 2011 | 11:56 AM
wallz's Avatar
wallz
They should as you are in a pickup. The X they don't because the rear set of doors are actually a little wider than the pickup. I have not seen it done but have heard of success, I just don't know if the mounting is all the same. At worst you will need the hardware from the window/mirror controls as the shapes are different. Again tho color will play as they will be slightly different shades.
Brad Wissinger
Jan 27, 2017 05:31 PM
x94ray
Nov 26, 2016 06:36 PM
17stroker
Nov 19, 2016 08:54 AM
Silverfox0921
Oct 18, 2016 09:52 PM
TravisMalone_89
Aug 16, 2016 04:02 PM
