missing after mud and water
Old Mar 9, 2003 | 08:45 PM
bugeyed's Avatar
bugeyed
ok i go offroading like once a month and hte last 3 times i've gone this has happened to me. I'll be going along through holes fine ll day long and then i'll hit one hole and all the sudden the truck will either stall or miss really bad when i try to rev it up quickly. Like when i punch it it will miss and make the noise of a rattling can within the engine. but if i just slowly rev it up it will accelerate. It really loses alot of power. Like its so bad if i get it started it won't even climb up slight inclines in 2 wheel drive. In 4 wheel drive forget about it it won't even start moving before it stalls. But heres the strange thing when i take it out onto a main road and slowly ease it up to around 45-55 and run it like that for 3-5 minutes it becomes perfectly fine again! I'm thinking i'm splashing over the EFI computer and its just drying off as i ease it up in power. What can i do to stop this! ITs reall hard when your at the bottom of a hill in a mudpit.
Old Mar 9, 2003 | 09:44 PM
ROTCJS's Avatar
ROTCJS
actually your probably getting your distributor wet.
Old Mar 9, 2003 | 10:27 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Second that, You are probably gettin water and/or muck in your distributor. You should stop your truck, pop the distributor cap off, and clean it out with WD-40 and a rag. I had to do this once, but in my case I got so much water in it that the engine died. Luck for me I had the WD-40 rolling around the bed and it will really help get the crud out of the distributor and cap. Hope this helps you bugeyed.
Old Mar 9, 2003 | 10:28 PM
steve83's Avatar
steve83
ROTCJS is right - it's not the EEC that's getting wet. You can get the distributor boot off a 5.0L Crown Vic/Grand Marquis/Town Car, &/or seal your distributor with silicone.
Old Mar 9, 2003 | 10:42 PM
optikal illushun's Avatar
optikal illushun
had the same problem on my truck after a mud bog up to my XLT emblems...but also a spark plug came loose...weird, huh
Old Mar 10, 2003 | 05:49 AM
bugeyed's Avatar
bugeyed
i checked my plugs but you think its the distributar? whats the cap of the crown victoria is that a sealed one?
Old Mar 10, 2003 | 07:23 PM
straight 6's's Avatar
straight 6's
Mine does this EVERY time i wash it.
Old Mar 10, 2003 | 08:26 PM
steve83's Avatar
steve83
The CV has a rubber boot over its distributor that you can get from a junkyard (or maybe a dealer) and put on yours. It fits loosely, but I can say from experience that it helps.
greenstar
22
Dec 14, 2013 05:00 PM
82fordguy
1983 - 2012 Ranger & B-Series
73
Oct 4, 2013 09:18 PM
NotFar
Apr 21, 2013 08:30 AM
PowerstrokeJunkie
36
Sep 17, 2008 10:16 PM
redhawk44
Oct 12, 2005 03:25 PM
